Drives: WRB Limited BRZ
Wanting to turbo my car, but....
Before I start, I am just planning ahead right now, I still have to pay off my car before I do anything to it. So I will not be buying a turbo kit any time soon until about a year. I am making this post so I can look back and reference to it when the time comes. I have been researching as much as I can and I have used the search feature and Google as well. The 2 biggest issue I been wondering is emissions and tuning.
I been looking at this turbo kit, Full Blown is the name. It's a turbo kit I really been interested in getting. The problem where I live at we have to pass emissions. Almost every turbo kit I've looked at for this car removes the cat converters. I spoke to a FullBlown vender here and he said they can make a downpipe with a cat in it but that doesn't guarantee that I'll pass when the time comes, hell what about that OBD test. I really don't wanna supercharge my car, I have nothing against SCs I just don't like them as they should only be in V6s and up (Yes, my opinion I know) So I'm asking, what are some of the work arounds you guys do? Another topic I would like to ask you guys, is the tuning process. Regardless of a turbo or supercharger I'm still going to need a tune. From what I've read I have to take my car to a local tuner in my area and they put it on the dyno and tune it from there. What I don't understand is what is a good tune compared to a bad tune, and why are they so expensive on kits like the basemap for example. I've read a thread here says something like "Anyone blown a stock boosted motor yet" and I read a lot of posts there and from what I'm seeing our motors were blown because of a bad tune. I'm not going to keep typing because this post was already long enough as it is but you all probably all get the idea. |
Good job on the research.
Drives: Asphalt FRS
First issue I see is your concern for emissions. To the best of my knowledge, there is not a single turbo kit out there (including ours) that would pass strict emissions or is CARB legal. Not only do you need to keep your OEM cats, but the tune will need to be set up correctly as well. I understand your issues with superchargers, but they will offer everything you are asking. All supercharger kits such as the Sprintex, Kraftwerks, Jackson Racing, Vortech will allow you to use your stock header and front pipe with the OEM cats, and most of those kits also offer a CARB legal tune as well.
As far as knowing a bad tune? Well there are a lot of variables, but the big ones are running too rich, or worse, too lean, poorly set up ignition timing that could cause detonation, starting and stalling issues, and the list goes on. |
NASA SpecE30 Racer
I would say that a properly catted downpipe and properly placed O2 sensors could allow you to pass emissions testing. You don't have to have a dyno tune, but you need a good tune which means you need to datalog it and have corrections made to the tune based on your setup. A good tune is worth any amount of money or any distance you have to drive to get it. I would say making the drive to HRI Tuning would be worth it for you.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: 2016 STi DGM
Guess takes a year to plan out what you want. By then there will be new products, new research, new lots of things. A year out sounds like a long time. Good luck
-2014 SSM BRZ MT
#6 | |
Drives: VW MK6 GTI | 13 Mustang GT
Some tuners have tunes to turn off the CEL but they merely mask the code on the ECU but it is still there being reported on OBD-2. Depending on your tune and state you could play with O2 sensors as mentioned but it's tricky or you can try some of the more drastic things that some VW guys do like swapping downpipes back to stock when state inspections come up.
Spun
Drives: 23' Supra
Have you ever heavily modified a car before? You need to be prepared for it...if you owe any money on the car I wouldn't even think about a turbo.
#8 | |
Drives: 2013 Firestorm FRS
In the mean time, you can pick up supporting mods! Suspension, bushings, oil coolers and other "bolt on" items |
Junior
Drives: a car
He mentions he is planning ahead once his car is paid off......t'was the first sentence.
#10 |
Drives: Slow
No cat? Spark plug defouler on the secondary oxygen sensor should take care of the code.
#11 | |
Spun
Drives: 23' Supra
OP also mentions just 'going to a local tuner', where I would caution that as well. I wouldn't bring this platform to just anyone, tuners usually specialize. |
#12 | ||
I don't know if you're messing with me, or insulting me because I'm asking questions. I'm not mad at your or anything it's just stuff written through text online gets blown out of proportion. I was just hoping you'd leave some feedback if you come back to this thread since you drive some BAD ASS cars lol.
I probably should add this to my OP post but I did look at some SC kits, (Vortech, Jackson, and Innovate) Yeah ironically as much as I don't like superchargers. I probably will have to go this route. Quote:
#13 | |
NASA SpecE30 Racer
- King Tut
#14 | |
Off Topic
More importantly, a few of the supercharger manufacturers have CARB-legal kits that come with a tune already. So hypothetically you could get the Jackson Racing CARB-legal kit, install it or have it installed, flash the ECU, and drive out with much more power without needing dyno time. Granted, a good tuner and a dyno can fine-tune the base map, but you could still drive out on just the base map if you wanted to. Since you have a year before you move on FI, you should look at supporting mods. Engine and drivetrain bushings, maybe an oil cooler, wheels and tires, suspension, etc... |
| Wanting to put on a new spoiler. HELP! | katcaylor | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 01-11-2014 11:46 PM |
| Wanting to put on a new spoiler. HELP! | katcaylor | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 12-26-2013 07:07 PM |
| Wanting some advice... | Atropine | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 10-17-2013 12:02 PM |
| wanting to get rid of my fbm turbo kit | Frs300 | Southeast | 0 | 05-04-2013 02:40 PM |
| Am i crazy for not wanting | mrlewistan | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 08-21-2012 07:45 PM |
