Old 10-19-2014, 09:27 PM   #1
PylonTheWins
PylonTheWins's Avatar
Drives: Subaru 2014 BRZ Limited
Music from External Drive
I was curious, is it possible to use an external hard drive to play music through the car?
PylonTheWins is offline   Reply With Quote
Old 10-19-2014, 09:42 PM   #2
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
I imagine it'd be easy. You might just have to power it separately. I'm not sure the USB port could power and play the music from it--but I'm certain it will pull the music files from it.
Candlejack is offline   Reply With Quote
Old 10-24-2014, 04:00 PM   #3
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
There is a 8GB limit according to the manual, so I am not sure how that would work with a hard drive...but I plan on finding out, as I want to try the same thing.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 10-24-2014, 06:23 PM   #4
dinoniel
I have a 2014 Limited with a 32gb sandisk USB without any issues. Can show album art and all that. Don't know if the 8gb limit is really accurate? Not sure if it applies to the SD card maybe
dinoniel is offline   Reply With Quote
The Following User Says Thank You to dinoniel For This Useful Post:
paiceyfan (10-24-2014)
Old 10-24-2014, 06:25 PM   #5
randomthoughts
Drives: 2014 White BRZ
^^ I use a 16GB usb stick as well. No issues.
randomthoughts is offline   Reply With Quote
The Following User Says Thank You to randomthoughts For This Useful Post:
Old 10-24-2014, 10:05 PM   #6
paiceyfan
paiceyfan's Avatar
Thanks...I have some experimenting to do, I think!
Old 10-24-2014, 11:03 PM   #7
paiceyfan
paiceyfan's Avatar
What's the largest size drive anyone has used?
Old 10-25-2014, 12:36 AM   #8
zeal86
zeal86's Avatar
Drives:
I've been using this [ame="http://www.amazon.com/gp/aw/d/B002HGFKR8?pc_redir=1413857460&robot_redir=1"]elago Mobile Nano II USB 2.0 microSDHC Flash Memory Card Reader -Works up to 32GB- (Black):Amazon:Electronics[/ame] with a 64GB Micro USB card, it works but there is a trick to it. You have to change the source to USB from another source prior to turning off the 86... meaning, If I were to turn off the 86 with the source mode in USB, the next time I start my car it just keeps showing the loading animation without ever actually loading. Even if I switch back to another source and then back to USB it will not load. Now, if I change the source from USB to for example the FM radio prior to shutting off the 86...the next time I turn it on I can switch it from FM to USB without hardly any delay. Weird but it works.
2014 6-speed Monogram (37J)
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
NIN69 (10-25-2014)
Old 10-25-2014, 12:47 AM   #9
paiceyfan
paiceyfan's Avatar
Originally Posted by zeal86 View Post
I've been using this elago Mobile Nano II USB 2.0 microSDHC Flash Memory Card Reader -Works up to 32GB- (Black):Amazon:Electronics with a 64GB Micro USB card, it works but there is a trick to it. You have to change the source to USB from another source prior to turning off the 86... meaning, If I were to turn off the 86 with the source mode in USB, the next time I start my car it just keeps showing the loading animation without ever actually loading. Even if I switch back to another source and then back to USB it will not load. Now, if I change the source from USB to for example the FM radio prior to shutting off the 86...the next time I turn it on I can switch it from FM to USB without hardly any delay. Weird but it works.
Thanks...sounds like a possible solution...I need 32GB or larger for my music. I have a Microsoft Zune, but cannot get it to work through USB...not surprised really.
Old 10-25-2014, 09:18 AM   #10
zeal86
zeal86's Avatar
Drives:
The good thing about the Elago Nano reader is how low profile it is... almost like it's not even there.
Old 10-25-2014, 05:34 PM   #11
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
It's not a size limit, its a number of files per folder limit. I think 255?
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
paiceyfan (10-30-2014)
Old 10-25-2014, 08:36 PM   #12
paiceyfan
paiceyfan's Avatar
Maybe that's why the manual limit of 8gb is being exceeded...
Old 10-31-2014, 11:09 AM   #13
BRZ'n
Drives: 2014 BRZ
I have a 250GB USB powered seagate harddrive in my car and it works great. It needs to be reformatted to FAT32. I have several hundred albums on it.
BRZ'n is offline   Reply With Quote
The Following User Says Thank You to BRZ'n For This Useful Post:
paiceyfan (11-02-2014)
Old 10-31-2014, 11:10 AM   #14
BRZ'n
Drives: 2014 BRZ
it also fits perfectly in the slot directly below the stereo.
paiceyfan (11-01-2014)
external harddrive, music
Does anyone never listen to radio/music and drive with windows down? tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 44 08-17-2014 02:09 PM
2014 OEM HEADUNIT USB MUSIC ISSUES (Cant browse music folders) VuDism Electronics | Audio | NAV | Infotainment 12 05-29-2014 05:47 PM
San Diego County - 3rd Annual Toys for Tots Drive. Food, Music, Raffle Prizes!!! Infamous Performance Southern California 36 12-09-2013 11:26 PM
External Hard Drive Hook Up Juurian Electronics | Audio | NAV | Infotainment 4 05-17-2013 01:47 PM
Playing music through USB drive... Jester Electronics | Audio | NAV | Infotainment 32 02-02-2013 06:56 PM
