Old 10-18-2014, 04:31 PM   #1
Tal
Tal's Avatar
Drives: Scion FRS 10 Series
GReddy turbo
Has anyone here tried the GReddy turbo yet?? If so, how much is your power out put, and how much PSI are you running?
10 Series Owner. Love it.
Tal is offline   Reply With Quote
Old 10-18-2014, 04:33 PM   #2
s2d4
s2d4's Avatar
FA20Club/TR3 bro.
Old 10-18-2014, 04:38 PM   #3
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-18-2014, 04:39 PM   #4
raven1231
Not yet man
In b4 the "stealzbydesign" comments....
Old 10-18-2014, 04:47 PM   #5
Tal
Tal's Avatar
Originally Posted by s2d4 View Post
FA20Club/TR3 bro.
Could I run this at lets say 7 PSI (safely) without changing internals?
Old 10-18-2014, 04:50 PM   #6
woode
Boosted Member
woode's Avatar
http://www.ft86club.com/forums/forumdisplay.php?f=78
I would recommend reading through the above forum. I heard there are even threads dedicated to various turbo kits and hundreds of posts with dynos at various boost levels on stock and modified engines.
Here is a nifty tool that not too many know about as well: http://www.ft86club.com/forums/search.php?f=78
Old 10-18-2014, 04:50 PM   #7
s2d4
s2d4's Avatar
No.
Old 10-18-2014, 04:55 PM   #8
Tal
Tal's Avatar
Instead of being a sarcastic asshole, you would see that I am new, and mind you I have already searched for topic on the GReddy turbo. HENCE WHY I AM ASKING.
Old 10-18-2014, 04:55 PM   #9
Tal
Tal's Avatar
No.
Thank you.
Old 10-18-2014, 05:00 PM   #10
woode
Boosted Member
woode's Avatar
Did you try searching for "Greddy" when you searched? You posted an open ended question instead of asking specifics without bothering to search. There are HUNDREDS of posts about greddy kits, and others as well.
Judging by your questions, you need to spend a lot more time researching forced induction in general.
Here are the first few I found with about 8 seconds of effort put into searching:
http://www.ft86club.com/forums/showt...t=greddy+turbo
Kids are so lazy these days, wanting everything spoon-fed to them..
Old 10-18-2014, 05:07 PM   #11
Tal
Tal's Avatar
And you just spoon fed it to me. Thank you,
Old 10-18-2014, 05:10 PM   #12
raven1231
Thank you.
I think 5psi Is the limit before internals need to be revamped
Old 10-18-2014, 05:13 PM   #13
Tal
Tal's Avatar
Thank you, I remember GReddy said that their turbo on stock internal at 7 psi produces 93.5 whp and 68.7 ft-Ib.
Old 10-18-2014, 05:45 PM   #14
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
I get that your new but woode is right you will get a lot of slack if you just start new threads when there is clearly a lot of threads already out there. if we keep restarting threads asking the same questions it makes it harder down the road to search the topics. that being said. Raven1231 Is likely feeding you information that is not necessarily correct. 7 psi seems to be the starting point for most people. I don't even think I have heard of anyone running less then 6psi. I am running 7 on my low map and 13 on my top map. making an extra 200 plus HP. some people are going higher then that but from what I see most people seem to stop between 12-15 psi on stock internals just to be safe. the key is a good tune. don't buy the kit and run the map they supply off the shelf at least not for a long time.. that map will allow you to drive it for a little while and get it down to a shop but it is definately not intended to be a high HP gaining map. just a safe one. just scroll through the forced induction part of the forums and you will find a wealth of knowledge on the topics. If you haven't done anything like this before I suggest going to a good shop (which can be found on here as well) and getting guidance, help and a good tuning. I wish you the best. good luck.
toekneehair is offline   Reply With Quote
Greddy Base Map for FRS Greddy Turbo Kit hiranak Software Tuning 10 10-27-2014 06:55 AM
Greddy turbo kit and AVO world turbo kit SPECIAL PRICING! THMotorsports.com Forced Induction 129 07-24-2014 06:51 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
