Old 10-15-2014, 12:33 PM   #1
D.Scrye
D.Scrye's Avatar
Drives: Hot Lava FR-S
So I've lost a fight with a tree root...
Saturday night I was relegated to parking on the grass, due to a lack of parking. There was a protruding tree root, that was just a bit more protruding than I thought it was... So, when I backed out the next morning it split the bottom of my front bumper- I seek advise on how to fix. I'm considering borrowing a plastic welder from an associate, or just drilling a pilot hole and sticking a tear aid patch over the crack. Any other ideas? I figure I'll eventually just stick a CF lip over it or get the TOM's bumper (there are some other abrasions as well), or something, in the long term. Thoughts?
TL: DR- broke bumper on tree root, need advice
Why not?
D.Scrye is offline   Reply With Quote
Old 10-15-2014, 12:38 PM   #2
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
Totaled
nah I have no idea how to fix that though
boooooooooooooooooost
Ammonia is offline   Reply With Quote
The Following 3 Users Say Thank You to Ammonia For This Useful Post:
BolognaWalrus (10-15-2014), Boofneenee (10-15-2014), illest86 (10-15-2014)
Old 10-15-2014, 12:45 PM   #3
MrBlaze-65
Drives: 2014 Subaru BRZ
Buy a polyurethane lip on ebay
secure to front bumper
continue on with life
eventually the lip will become damaged and you'll have to replace it but replacing a $60-$100 lip every year or two won't be so bad as replacing a $500 carbon lip that will show defects and wear much faster.
MrBlaze-65 is offline   Reply With Quote
Old 10-15-2014, 12:55 PM   #4
gramicci101
Off Topic
At the very end of the crack, drill a small hole. Because the crack is irregular with a specific fracture line, it's possible that it will continue to spread along that line. A drilled hole will be smooth and round with no single stress point, so it'll be less likely that the crack will spread past that point.
Then cover it with a lip and try not to drive into any more trees.
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
Boofneenee (10-15-2014), D.Scrye (10-16-2014), Stang70Fastback (10-19-2014), Tcoat (10-15-2014)
Old 10-15-2014, 01:04 PM   #5
D.Scrye
D.Scrye's Avatar
Anybody use a plastic welder before, or have any experience with tear aid on automotive plastic? It causes me some concern to just stick a lip over it without securing the crack first, for structural purposes.
Why not?
Old 10-15-2014, 01:16 PM   #6
RFB
RFB's Avatar
Drives: FRS
It wouldn't hurt to key the back and apply an epoxy putty patch (like tape).
Plumbers Seal is as hard as steel, but the green and yellow strip epoxy putty(forget the brand) is softer but more flexible.
CERBERUS
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
Old 10-15-2014, 01:37 PM   #7
Did plastic welding for a few years. A lot depend upon the type of plastic really. Probably be fine on the bumper plastic but as it is a weld, it will make a rather ugly line.
I would just drill the hole to prevent spreading (as said already) and put the lip on. Just make sure you secure the lip as close to either side of the crack as possible to give it some rigidity.
Old 10-15-2014, 02:01 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
like others said, go for a lip
Old 10-15-2014, 07:08 PM   #9
Guzic
Clean as F86ck
Guzic's Avatar
Drives: 2014 Asphalt FR-S
Remove bumper
Drill hole at the end of crack as gramicci stated
Scuff the back of the bumper where he crack is to apply some bondo
Apply a fiberglass sheet on top of the bondo before it dries to get a decent hold.
Apply bondo on top of fiberglass sheet
Touch up paint the front
Live life.
That's a quick and cheap way to fix it without replacing the bumber.
Guzic is offline   Reply With Quote
The Following 2 Users Say Thank You to Guzic For This Useful Post:
D.Scrye (10-16-2014), Tcoat (10-16-2014)
Old 10-15-2014, 09:21 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
This is the only stuff that will actually bond to polyethelene. It involves some surface prep but really works. Use a similar wide piece across the back side (think band-aid) to get some surface area for the adhesive to do its thing. http://mrstickys.com/mr-stickys-poly-bonder-glue-30g/
More of the same stuff. http://www.tapplastics.com/product/r...d_adhesive/435
Old 10-15-2014, 09:45 PM   #11
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
My advice:
Don't go down without fighting back!
Subaru STI :
The Following 3 Users Say Thank You to Kimsey47 For This Useful Post:
bama_brz (10-16-2014), D.Scrye (10-16-2014), Tcoat (10-16-2014)
Old 10-16-2014, 09:40 AM   #12
I would listen to Ultra because if anybody knows about something called "Mr. Sticky" he would!
gramicci101 (10-16-2014)
Old 10-16-2014, 01:23 PM   #13
Ultramaroon
not playing cards
I never wash.
Who would win in a fight? Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 26 04-05-2016 04:07 PM
Triple XXX Root Beer Import Meet 23 Feb 2014 Hippophobia Northwest 22 02-23-2014 09:59 PM
Car vs. Tree Joakim3 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 11-15-2013 11:19 AM
Let's See Your Tree! FRavenS Off-Topic Lounge [WARNING: NO POLITICS] 13 12-05-2012 11:46 PM
7 vs 1 behind school fight Giccin Off-Topic Lounge [WARNING: NO POLITICS] 45 01-17-2012 08:50 PM
