Old 10-13-2014, 03:24 PM   #1
toast
Drives: 14 BSP Edelbrock BRZ
GTSpec fender braces?
Anyone running these? I haven't had to the fender off to see what the unibody looks like under there, but I know in my 02 WRX they made a world of difference.
toast is offline   Reply With Quote
Old 10-13-2014, 03:43 PM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
How was it different? I'm looking into this too.
Tye300 is offline   Reply With Quote
Old 10-13-2014, 04:05 PM   #3
toast
On the WRX just driving over the transition from my driveway to the street you could feel less body flex. The whole car felt more rigid.
Old 10-13-2014, 10:17 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Interesting, so exactly what would the fender braces do? Kind of like how a sway bar stiffens up body roll as an analogy to this?
Old 10-13-2014, 10:41 PM   #5
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I haven't heard of fender braces since i was 16. I always thought they were a bit of a joke, there was an Inifinty owner i knew who had a custom made one. Running cheap all seasons and fender frame sure made a wall of difference in his mind. Always felt those mods were a joke, something to tell off at car shows.
Would be interesting to see what people think about them.
Picture reference.
Here's a snip it i quite like from reading a review...
I also say it because I use to be a poster boy for "cool" parts on my Miata. I had the full FM frame rails, butterfly brace, Boss Frog braces, and even the full Carbing brace setup.
All that stiffening didn't improve my times. I was getting passed by guys who had a much more simpler approach and actually knew what parts they were adding before they were added.
Save yourself the money. There are definitely other items to address on this car.....like that trans issue that Eric wasn't talking about. What's the point of having all that bracing when you third gear goes out and ends your season!
Old 10-13-2014, 10:51 PM   #6
toast
It all depends on what the unibody bracing is like stock. On the impreza their is a large vertical box section in front of the door and then a horizontal box section heading to the front. Triangulating the two helped a lot. On the STI there is one present from the factory. I'm not worrying about improving my lap times, a stiffer car just feels nicer to drive and let's the suspension do what it is designed to do.
Old 10-13-2014, 10:52 PM   #7
toast
Don't have any idea how I just did that goofy text transition...
Old 10-14-2014, 01:08 AM   #8
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Fender braces make a huge difference in chassis stiffness. That area of the car is rather weak because it is part of the crumple zone. When you're in a front end collision the chassis collapses in this area to absorb crash energy and protect the vehicle occupants. On that note, do they make a difference, yes. Will they put your safety at risk, again yes.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 10-14-2014, 02:37 AM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I had them on my S13.
Makes a bigger difference on softer unibody designs, namely older cars.
It does take away some of the safety built-in to the car (crumple zone), but frankly for our cars it's not worth it since the front end is fairly stiff with the stock triangulated strut bar.
-alex
Old 10-14-2014, 03:10 AM   #10
abraxis
Drives: many
-alex
Except the stock bar isn't actually triangulated. In math and engineering, 2/3rds of a triangle =/= a triangle. If I only have half a wheel, I don't call it round and pretend it will roll.
abraxis is offline   Reply With Quote
Old 10-14-2014, 06:37 AM   #11
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
The OE bracing forms 2 rough triangles connected at the firewall on the top of the engine bay. The firewall and the fender/wheel wells for the 2 other sides of the triangles. 3 sides each. Crossbar connecting the strut towers will make 3 triangles.
Old 10-14-2014, 11:05 AM   #12
toast
None of the braces under the hood address vertical flexing of the front end of the car. After talking about it so much I'm now intrigued enough to pull off a fender and see what the unibody looks like...
Old 10-14-2014, 12:23 PM   #13
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
If you do this, please post photos.
dradernh is offline   Reply With Quote
Old 10-14-2014, 12:52 PM   #14
abraxis
Drives: many
2 weak triangles that divide the front of the chassis in half? Independent suspension is a good thing. An independent chassis is not. Point is, the stock front brace does not completely triangulate the front of the chassis. Thus, it is not triangulated. If you want to say the wheel well is triangulated, go ahead.
Still, I dare anyone here to put a GoPro on the side of their door and track the car, then post the video proving the fenders don't move or flex towards the door with stock bracing.
FS: GTSPEC STB jeffs42885 Brakes, Suspension, Chassis 2 05-08-2014 01:27 AM
FS GTSPEC STB jeffs42885 Brakes, Suspension, Chassis 4 03-06-2014 02:57 PM
*GTSpec Chassis/Suspension Components Thread - Struts, Sways, Braces* -fteightysix 86SPEED Brakes, Suspension, Chassis 20 10-19-2013 12:56 AM
GTSPEC Suspension braces on BRZ with 18x9.0 and 18x10.0 WORK Emotion XD9 RavSpec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-13-2013 09:10 AM
**GTSPEC Suspension Braces now available for Scion FR-S / Subaru BRZ** GuerillaRacing Brakes, Suspension, Chassis 4 05-24-2013 11:05 PM
