Old 10-10-2014, 06:54 AM   #1
voivoi
Drives: GT86 TRD Pearl White
Difference between GT86 and FR-S?
Howdy!
Norwegian GT86 owner here.. I`ve been looking for a supercharger kit a while now, but as far as I can see theres a difference between the FRS and the GT86 engine bay. Does any of you know what that is? Its a bit frustrating, since most of the supercharger kits are from the US.
voivoi is offline   Reply With Quote
Old 10-10-2014, 08:01 AM   #2
kevman_101
Drives: 2013 Scion FRS
If it`s a left hand drive like in the US, I would think it should be nearly the same car. The GT86 can be equipped more then the FRS here and probably resembles more like a BRZ in terms of equipment the the FRS. If the kit fits an FRS and BRZ, and it`s the same drive side, I can`t think of why it wouldn`t fit. But I would wait until someone more qualified answered hehehe.
Also, what do you find looks different? Try to get a pick of the differences if you can and that could help as well to spot something that could cause an issue in fitment.
kevman_101 is offline   Reply With Quote
The Following User Says Thank You to kevman_101 For This Useful Post:
Tcoat (10-10-2014)
Old 10-11-2014, 10:40 AM   #3
voivoi
Jupp, I know about som small cosmetical differences, but Im thinking of the engine bay mostly. I bought som hood shockers from ebay, and they didnt fit for example.
Quote from Jackson Racing:
Q: Will you offer a kit for Asian and European owners?
A: International compatibility is being evaluated and will release shortly.
Quote from an british supplyer:
"These kits are not for the feint of heart. The Tuner kits are designed for US vehicles and do require slight tweaking, Please do not purchase without contacting us first . It is not a case of just bolting it on and suddenly getting an extra 80bhp the standard car wasn't made to take that amount of power as standard. The kits require supporting mods to keep your oil temperatures down and fuelling correct. Mods such as fuel injectors, gauges, fuel pumps, thermostat, and more"
http://www.tarmacsportz.co.uk/GB/GT8...218-114L_.aspx
Old 10-11-2014, 06:57 PM   #4
synchromesh
synchromesh's Avatar
Drives: Ultramarine Blue
I wouldn't be surprised if you sent a crate of you guy's nice salmon over there to Japan, they would gladly ship you over some kind of FI kit. Good luck OP.
synchromesh is offline   Reply With Quote
Old 10-12-2014, 04:38 AM   #5
Nik33615
Nik33615's Avatar
Drives: 2013 FR-S MT
It's possible the U.S. kits wouldn't fit because possibly the U.S. cars and the European models may have different emissions equipment. Just a guess I really don't know this for sure.
Nik33615 is offline   Reply With Quote
Old 10-13-2014, 04:20 AM   #6
voivoi
Hehehe..
Old 10-13-2014, 04:26 AM   #7
voivoi
Can you elaborat please? I think its a mechanical issue.. the only difference I can see is that you motsly drive on 92 octane, right? We only have 95 and 98 here in Norway.
Old 10-13-2014, 10:31 AM   #8
The octane levels are actually the same. The numbers are different because they are measured differently.
Old 10-13-2014, 11:09 AM   #9
troek
troek's Avatar
Drives: 2012 Toyota 86
master brake cylinder and battery are swapped. should be bout it. i could see how that may cause some clearance issues.
Old 10-13-2014, 11:47 AM   #10
Nik33615
Nik33615's Avatar
Different regulations in different countrys may mean that my FR-S in the U.S.A. may have a different sensor(s) or more or less parts on the engine due to differing emission requirements. That would mean there is a mechanical difference although subtle.
Still I want to re-state I do not know for a fact, what if any actual differences there are between U.S. and Euro 86s.
The Following User Says Thank You to Nik33615 For This Useful Post:
Tcoat (10-13-2014)
Old 10-13-2014, 11:53 AM   #11
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
The spring rates are different. Also, Interior features, headlights (obviously things available on the special releases here). Some territories have lower optioned cars that have 16" wheels and possibly open diff (base Japanese trim has open).
Also, the 98RON you have is equivilant to our 95 octane (which is hard to find). Your 95 is close to our 92-93 octane
Engine bay wise, physical modifications can be limited due to LHD vs RHD models due to steering rack. A LHD GT86 engine bay should accept same mods as FRS and vice versa.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
Tcoat (10-13-2014)
Old 10-13-2014, 11:54 AM   #12
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
The spring rate for the suspension is slightly different. But overall it is pretty much the same vehicle. The GT86 has softer ride compare to the FRS.
Muaddib is offline   Reply With Quote
Old 10-13-2014, 12:08 PM   #13
Kido1986
Dodging cones
Kido1986's Avatar
Stiffer front springs than FR-S and softer rears. Comfort is a wash with that, hard to say.
Old 10-17-2014, 10:57 AM   #14
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
There is no difference which may prevent any SC kit, which fits FR-S, from fitting a EUDM GT86. Difference under the hood between MT and AT is noticable. Between FR-S / BRZ / GT86 / 86 - not (if they all have the steering wheel on the same side). Sizes of the battery may slightly vary but that's it.
Efferalgan is offline   Reply With Quote
cat/no cat hp difference? EN2_Squirrel Engine, Exhaust, Transmission 6 11-17-2013 09:32 PM
LED vs HID: what's the difference? GhostofAkina Cosmetic Modification (Interior/Exterior/Lighting) 13 04-06-2013 07:23 AM
Need help, GT86 left and right height difference K-R Scion FR-S / Toyota 86 GT86 General Forum 8 08-20-2012 03:13 AM
