Drives: Scion FRS
Gram lights 57fxx
Ok guys I need help, I'm getting gram lights 57fxx 18x9.5+38.
I'm going to be running 245/35R18 front 255/35R18 rears How much camber can I run that will make my tires last a few? I'm also going with buddy club LCA. Any info is always grateful. Thank you |
Drives: 2013 DGM BRZ
Tires: I'd run 255/35/18 non-staggered size.
Camber: depends on how much you lowered the car as well as the specific tire, since not all 255 tires are actually the same width, but anywhere from -1.5 to -2.5 is my guess. Toe has a much larger impact on thread wear than camber. Make sure your toe is 0 when you do the alignment and you should be fine.
![]() Saorri for mah bad English ![]() |
Drives: Series 10 FR-S
I already did this setup. Check out in the link below.
http://www.ft86club.com/forums/showthread.php?t=63626 |
| Wheel Directory: Gram Lights 57FXX 18x9.5 +38 | raytrix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 01-02-2019 12:49 PM |
| Wheel Directory: Gram Lights 57FXX 18x8.0 +45 | Ray_32 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 07-17-2017 01:08 PM |
| FS/IL> Gram Light 57FXX 18x9.5 +38 5x100 Black Machining finish | raytrix | Wheels and Tires | 14 | 06-09-2014 09:21 PM |
| Wheel Directory: Gram Lights 57FXX 18x8.5 +45 | r4m3n | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-17-2014 02:22 PM |
| Gram Lights 57FXX | TRD-X | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 47 | 03-08-2014 05:07 AM |
