Old 10-04-2014, 04:48 PM   #1
Crows
Drives: 2014 BRZ Limited
I just want to change the tips
Like a lot of people, I don't like the stock exhaust tips on my 2014.
After a lot of research on all the different exhausts out there, I decided I do not want to alter the sound, so I thought I would just change the tips.
I really like the Perrin tips, but decided to try the 2015 stock tips. So I ordered a set. I am the least mechanical guy you've ever heard of, so much so I considered having the dealer install them for me, but then thought how dumb I would look, so I gave it a shot.
Driver side one came off no problem, but when I tried the other, the bolt head just twisted right off ! Maybe I was turning it the wrong way ? Even if that were so, I barely applied any pressure, it just broke off so easily.
Is there an idiot proof way to remove this bolt now ? Or do I need a mechanic to fix it ? Any suggestions would be appreciated.
Crows is offline   Reply With Quote
Old 10-04-2014, 04:53 PM   #2
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
You could get a left handed drill bit and drill it out, or go to a local harware store and get an EZ-Out kit which will require a drill aswell. It's honestly really easy if you have that and should work without a problem.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 10-04-2014, 04:57 PM   #3
kALMIGHTY
Drives: TRD Ultramarine '13
Both my bolt heads twisted off when I tried to change my tips. I gave up trying to get them out myself so I just went ahead and took it to Minute Lube. They torched them right off for me.
Old 10-04-2014, 05:41 PM   #4
Crows
Thanks guys ! I am going to home depot later so I will see what they have to help remove it. If it looks too hard I will take it in.
Do I need to order the replacement bolts from Subaru ? Or could I get those at Home Depot to ?
Old 10-04-2014, 06:42 PM   #5
Rapiddan45
Rapiddan45's Avatar
I would take the one in that came out fine and just get 2 more of those.
Old 10-04-2014, 07:10 PM   #6
kALMIGHTY
The tips I got had their own built in screws so I didn't need to worry about new bolts but if yours didn't come with their own, just find the same size ones from Home Depot. Preferably the powder coated ones to avoid rusting like the OEM ones did.
Old 10-05-2014, 12:13 AM   #7
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
just the tip?
Grymm86 is offline   Reply With Quote
Old 10-05-2014, 02:25 AM   #8
humfrz
With your experience, I'd suggest you take your car up to a muffler shop and let them fix it .....
humfrz
Old 11-23-2014, 05:14 PM   #9
ArmBRZ
ArmBRZ's Avatar
Drives: 2013 Lighting Red BRZ
Whats the part number for those 2015 tips?
ArmBRZ is offline   Reply With Quote
Old 11-23-2014, 08:48 PM   #10
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'd suggest asking around the Aussie sub-forum. A lot of people down-under have taken off their stock exhausts and probably wouldn't mind selling you the just the JDM tips as they are stock on all Aus delivered cars.
If no luck there maybe try the Australian Facebook 86/BRZ parts market.
https://www.facebook.com/groups/86brzbuysellswap/
Wise is offline   Reply With Quote
Old 11-23-2014, 09:43 PM   #11
BRZnut
Drives: BRZ DGM Limited
when that happened to me I just wedge a screw drive under the old tip (from the back) and just pulled down on the screw driver just enough to bend the old tip so that I could slip it off. Took some effort but not hard.
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 01:45 PM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
WTB: JDM exhaust tips or perrin tips calvinck Canada Classifieds 0 06-01-2014 11:17 PM
WTB: DC Exhaust Tips or Other Tips Xdragonxb0i Engine, Exhaust, Bolt-Ons 2 05-10-2013 06:36 AM
Let's keep it simple, I want to change out my exhaust tips. Liquidsnake Engine, Exhaust, Transmission 11 06-30-2012 03:08 AM
