Old 10-03-2014, 08:24 PM   #1
van_fc3s
Drives: GT86
will rpf1 73mm work w our frs?
quick question
will 17x8 +45mm and center bore 73mm work on our car?
sorry for the newbie question.
my first ever aftermarket rims.
also can I just transfer my tire and tpms onto this rim?
van_fc3s is offline   Reply With Quote
Old 10-03-2014, 08:33 PM   #2
TestaRossa
TestaRossa's Avatar
Drives: 2013 DGM BRZ
http://www.ft86club.com/forums/showthread.php?t=10257
Just make sure you buy them in 5x100 bolt pattern and 4 hubcentric rings (not required but recommended)
Saorri for mah bad English
TestaRossa is offline   Reply With Quote
The Following User Says Thank You to TestaRossa For This Useful Post:
vividracing (10-03-2014)
Old 10-03-2014, 08:40 PM   #3
vividracing
vividracing's Avatar
@van_fc3s Great choice of wheel! As long as the bolt pattern is 5x100, the specs you have listed above will work just fine. The 73mm hub bore is in place to allow for multiple applications. It is best to get a set of hubcentric rings when running after market wheels to ensure proper wheel alignment when mounting on the vehicle. As far as your tires and TPMS sensors swapping, that also should not be an issue. When swapping the sensors you will need to purchase sensor specific rebuild kits, that include new rubber seals, valve core, and grommet. Tire shops such as Discount Tire can provide you with all of this and can mount and balance the tires on the new wheel for a small fee. Hope this helped. Happy motoring, please feel free to pm with any more questions you may have regarding your FRS. Happy Motoring!
Taylor
vividracing is offline   Reply With Quote
Old 10-03-2014, 11:34 PM   #4
van_fc3s
Drives: GT86
thank you so much for the prompt reply guys am really trully appreciated along w the tips.
WTB:enkei RPF1\forgestar F14\Work emotion both 18 5x100 (vancouver) pongpongchan Want-To-Buy Requests 0 07-28-2014 10:07 PM
Factory wheel-locks work with RPF1? Namuna Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2014 10:12 AM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
[SYD] Gorilla Automotive Hub Centric Rings (73mm OD x 56.15mm ID) eckoflyte Australia Classifieds 0 08-27-2013 05:26 AM
Work Emotion CR or Enkei RPF1 ? ategs1992 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 02-20-2013 02:32 PM
