Old 10-02-2014, 09:13 PM   #1
jflogerzi
jflogerzi's Avatar
T-Stat oil cooler for Socal on a daily car
Looking at getting the 19 row Mishimoto oil cooler and I can't decide do I really need a t-stat version in socal weather.
Old 10-02-2014, 09:24 PM   #2
mike the snake
I'd say yes, no matter where you live. Unless the car is a dedicated track car, you need the thermostat.
Old 10-02-2014, 09:27 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I don't have a t-stat. Live in Miami. Car is not DD. But when I use it, so far always reach opersting temp. Cooler is located in same spot as FBM cooler. In winter its probably going to be harder to get to operating temp but I bet it gets there.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jflogerzi (10-02-2014)
Old 10-02-2014, 09:34 PM   #4
jflogerzi
jflogerzi's Avatar
Your boosted generating more heat. I will wait for more people chime in
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Sportsguy83 (10-02-2014)
Old 10-02-2014, 09:37 PM   #5
Sportsguy83
Drives: Limited BRZ
Good point.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 10-04-2014, 12:34 AM   #6
jflogerzi
jflogerzi's Avatar
For 550$ shipped to my door I ordered the Mishimoto oil cooler with a t-stat just to be on the safe side. being a 19 row cooler should be plenty for 100+ degree track days in CA boosted might be a different story but na should be fine
Old 10-06-2014, 06:19 AM   #7
AJPG
Drives: 22RE, FA20, 4G63
With 19 rows and NA you should be fine at heavy track use (that's for engine oil)... But I didn't see it or look for it, is your car MT or AT?
AJPG is offline   Reply With Quote
Old 10-06-2014, 08:19 AM   #8
jflogerzi
jflogerzi's Avatar
6sp mt
Old 10-06-2014, 01:33 PM   #9
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
In Socal running Jackson Racing oil cooler w/o thermostat. Oil gets to 190F minimum. On cool nights I get up to 185F minimum. I am planning on installing a thermostat when it gets cooler in the winter.
JDKane527 is offline   Reply With Quote
Old 10-06-2014, 01:55 PM   #10
kingnba6
Drives: 2015
i never dealt with aftermarket oil coolers and never thought in my head that i would need a thermostat for it. good reading.
kingnba6 is offline   Reply With Quote
Old 10-06-2014, 03:12 PM   #11
Dezoris
Dezoris's Avatar
0w20 flows extremely well and can be operated in the 175-185F range and oil pressures will be excellent. If you are running a cooler with no T-Stat and you are always in those temp ranges you are good.
But if you are struggling to get up to those temps in warm climate on a daily driver you will want a t-stat. I would always running a t-stat cooler on a street car, which 95% of the cars on this forum are.
SCCA Socal Solo 2 at El Toro, Socal, 3/22-23, noob questions JB86'd Tracking / Autocross / HPDE / Drifting 52 03-29-2014 04:00 AM
OMG i want to kill my stat nav skye67 Electronics | Audio | NAV | Infotainment 5 02-22-2014 06:51 PM
Bizzare stat discovered randomly today. erom Scion FR-S / Toyota 86 GT86 General Forum 6 02-03-2014 02:21 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
