Old 10-01-2014, 07:41 PM   #1
NOHOME
Drives: RAVEN
Car back from bodyshop..FM radio not working?
So, after having a fender and a door replaced I picked up the car today and all looked good.
Until I turned on the radio for the drive home. The FM radio sounds like shit. Its like every FM station is just off frequency a bit with a lot of static and crakle.
AM radio seems to work fine.
Any chance this might be related to a battery being disconnected while the car was worked on? Is there a reset process that I need to perform?
NOHOME is offline   Reply With Quote
Old 10-01-2014, 07:53 PM   #2
Can't imagine a reason why but could they have unhooked the antenna? Wouldn't effect the AM as much as the FM because they both use totally different signals types.
Old 10-02-2014, 09:47 AM   #3
Purdue FR-S
Boiler Up!
Purdue FR-S's Avatar
Drives: 2018 BRZ tS
Did they throw it through the wash at the end?
Sometimes it loosens the antenna a bit. I had a similar problem. Try removing and reattaching the antenna and see if that helps.
Purdue FR-S is offline   Reply With Quote
Old 10-02-2014, 09:57 AM   #4
GOOD call! I had the same thing happen but forgot all about it.
Old 10-02-2014, 02:20 PM   #5
NOHOME
Drives: RAVEN
Fixed.
Since the battery had been disconnected, the system reset to default. Had to be told that it was not speaking to a Scion TC.
Old 10-02-2014, 02:22 PM   #6
Originally Posted by NOHOME View Post
Fixed.
Surprisingly enough a lot of people put it on that setting on purpose!
Glad too hear that is all it was though. Your description of the symptoms made it sound like a bigger issue.
Old 10-02-2014, 02:27 PM   #7
El Guapo
Fixed.
I am not understanding what you did to fix the issue, could you explain it a little better? I am having a similar issue with my car.
El Guapo is offline   Reply With Quote
Old 10-02-2014, 03:20 PM   #8
HiredGun
Livin' the dream
HiredGun's Avatar
Drives: 2013 Toyota Avalon
There is a button on the radio (i'd have to look at one to figure out which one) if you hold it down it goes into a different menu. Since the same radio is available in other scions, you can select which car your unit is in. It configures the sound differently, although I'm surprised this would effect static in any way.
HiredGun is offline   Reply With Quote
Old 10-02-2014, 03:30 PM   #9
Little thing that came with the car called "an owners manual" that tells you all you need to know about setting it! Mind you the search feature in the book sucks but it is there.
Sorry that was supposed to be done in a joking tone but looks more like sarcasm when written!
Old 10-02-2014, 03:34 PM   #10
HiredGun
Livin' the dream
HiredGun's Avatar
Old 10-02-2014, 03:40 PM   #11
You know the sad part is I get told ALL the time I look like BOTH those guys! Son (he is 30) says if they ever want to change scenes in Batman movies and Oldman isn't available I can stand in!
Old 10-02-2014, 03:45 PM   #12
HiredGun
Livin' the dream
HiredGun's Avatar
Good ole' Ned. If he were IRL I would totally have a beer with that guy
Old 10-02-2014, 04:25 PM   #13
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Here you go.
Sigh-on-Rice is offline   Reply With Quote
Old 10-02-2014, 06:39 PM   #14
El Guapo
Thanks @Sigh-on-Rice for the help! Hopefully this fixes the problem with my radio. I have been looking for a few days to see if I could find anything related to what's going on with my radio, but I haven't had any luck.
Stock radio stopped working? Shaun Perry Northern California 2 10-01-2014 01:55 AM
BRZ, FRS w/ Bespoke radio back up camera kit 06d Audio/Visual, Electronics, Infotainment, NAV 0 07-31-2014 08:28 PM
Hamilton area bodyshop rec? cortrain CANADA 2 03-18-2014 08:25 PM
bodyshop around boston? rainmonkey New England 5 11-02-2012 03:38 PM
DFW REPUTABLE bodyshop? dawnst3ar Southwest 1 09-26-2012 03:14 PM
