Old 09-30-2014, 12:59 PM   #1
geezer86
Drives: 2014 FR-S red
Fogs on high beam only
My fogs only work on high beam or when the head lights are off.
So.... driving not fog? Is that normal?
geezer86 is offline   Reply With Quote
Old 09-30-2014, 02:04 PM   #2
ScorpionOzzy
Drives: Scion FR-S
Sounds like you tapped into the high beam for power. Since the high beam is also the DRL, it's pulling power when the headlights are off and the DRL is on. Since the DRL turns off when the headlights are on, you're not providing power to the fog lights. Tap into a different power source.
ScorpionOzzy is offline   Reply With Quote
High Beam - Foglight VA FRSure Cosmetic Modification (Interior/Exterior/Lighting) 0 03-10-2014 10:34 AM
DRL / High Beam LED bulbs Gps360 Cosmetic Modification (Interior/Exterior/Lighting) 7 09-04-2013 09:50 PM
DRL or high beam or both? jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 5 06-09-2013 03:09 PM
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 04:56 PM
