Old 09-29-2014, 07:11 PM   #1
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
WORKS Exhale AB (Axle Back) Exhaust
The WORKS Exhale AB (Axle Back) Exhaust is part of our modular exhaust series for the FR-S and BRZ that allow you to quickly and easily mix and match the MP (Mid Pipe) and AB (Axle Back) with any of the factory exhaust components.
The WORKS Exhale AB (Axle Back) Exhaust is a straight through design. Features 64mm (2.5") tubing, stainless steel 455mm (18") glasspack resonator and beautiful 102mm (4.0") double walled (prevents yellowing and heat exposure to rear bumper), stainless polished tips with the "WORKS" etched logo. The tips are also positioned to match the contour of the bumper. Direct bolt-on to the factory flange and utilizes all 4 hanger locations with OEM-style mushroom end hangers for precise fitment and swaps back to stock in minutes. Includes gasket and simple installation instructions.
By itself, the gains (~2 HP) are minimal in NA (naturally aspirated) form. Further gains can be obtained by including the WORKS MP to complete the cat-back system and/or WORKS ECU Brain Flash P1.
The WORKS AB will save you 10.5lbs compared to stock for an additional performance advantage.
Through the use of a stainless steel 18" glasspack, the Exhale AB has a slightly louder and more aggressive sound than our Exhale ABM (which uses a muffler instead), but is still mild mannered during idle and cruising. The controlled, deep, throaty growl is a tone that some say is the best sounding FR-S/BRZ exhaust they've heard!
Price: $369
Remember that if you have not used our ft86club discount code, we are offering forum members a one-time coupon for 10% off of your entire order for WORKS brand products! Enter “ft86club” in the coupon code box when you place your order.
Link to web-store listing: http://store.worksmotorsports.com/Pr...2E211&CartID=1
WORKS is offline   Reply With Quote
Old 09-30-2014, 10:18 AM   #2
lucid215
i want your mid pipe haha
lucid215 is offline   Reply With Quote
The Following User Says Thank You to lucid215 For This Useful Post:
WORKS (10-01-2014)
Old 10-01-2014, 07:35 PM   #3
WORKS
WORKS's Avatar
You should pick one up!
Old 10-03-2014, 07:19 PM   #4
WORKS
WORKS's Avatar
A couple videos to give you a better idea of the AB's sound.
[ame]http://youtu.be/dVTdgkp1k98[/ame]
[ame]http://youtu.be/UR9U2JeHpnc[/ame]
Old 10-04-2014, 07:11 PM   #5
pantdino
Drives: Firestorm 2013 FR-S
I did a post on this earlier today but it seems to not be there, so I'll repeat it here
It looks to me like only the right tip is muffled and most of the gasses will just go out the left tip because there will be less resistance to flow there.
No?
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 10-06-2014, 02:40 PM   #6
WORKS
WORKS's Avatar
No?
Hi pantdino,
Good question.
That is correct that one side passes through the resonator and the other does not. That said, we spent a lot time tuning the left side outlet size (it is slightly downsized) to achieve a good balance between the sound and flow through the two outlets.
This results in both outlets being functional. The design allows for simplicity in construction, smaller packaging and weight savings all while still producing the same power gains as a straight pipe in naturally aspirated cars.
Cheers.
Old 12-09-2015, 02:29 PM   #7
WORKS
WORKS's Avatar
Our 304 stainless polished tips look great with the OEM rear diffuser.
Old 09-20-2016, 05:20 PM   #8
WORKS
WORKS's Avatar
For the remainder of SEPT enjoy shipping on us! Use the promo code on our site on any WORKS products - FT86FREEGROUNDSEPT
Old 11-23-2016, 10:46 PM   #9
invaliduser
Drives: 2017 86
Fyi the axelback does not bolt right up to the 2017 86/BRZ. Holes on the flange do not line up.
Sent from my Pixel XL using Tapatalk
invaliduser is offline   Reply With Quote
The Following User Says Thank You to invaliduser For This Useful Post:
Lonewolf (12-04-2016)
Old 12-01-2016, 07:39 PM   #10
WORKS
WORKS's Avatar
PM sent. Thank you for letting us know!
Old 12-07-2016, 04:32 PM   #11
Veeoh
Veeoh's Avatar
I have this on my car. Love the sound of it. Has enough rumble and growl but not so loud that it'll be annoying.
Veeoh is offline   Reply With Quote
The Following User Says Thank You to Veeoh For This Useful Post:
WORKS (12-07-2016)
Old 12-07-2016, 06:29 PM   #12
WORKS
WORKS's Avatar
Good to hear! Cheers.
WORKS Exhale ABM (Axle Back Muffler) Exhaust WORKS Engine, Exhaust, Transmission 94 04-17-2019 01:40 PM
WORKS Exhale ABM (Axle Back Muffler) Exhaust WORKS Engine, Exhaust, Bolt-Ons 80 11-07-2016 04:00 PM
SOLD! NorCal_Guy Engine, Exhaust, Bolt-Ons 31 10-06-2014 09:44 PM
Works ABM vs. Nameless axle back 4in mufflers BlackyRose Engine, Exhaust, Transmission 12 08-29-2013 11:11 PM
WORKS ABM (AXLE BACK MUFFLER) EXHAUST J-Money Engine, Exhaust, Transmission 1 02-02-2013 11:49 PM
