Drives: 2013 Subaru BRZ Limited 6sp DGM
amount of fluids needed?
I see everyone changing diff fluids and trans fluids. How much of each fluid do I need and what is best? Ice seen motul 300.
Off Topic
2.2L in transmission and 1.3L in the diff.
I put Motul Gear 300 in both, purchased from @AZP Installs. You could get Motul Gear 300LS for the diff, but the regular 300 works just fine. The Motul bottles have a fill spout integrated into them; otherwise you'd need a fluid pump. Basically, fill both until fluid starts to weep out of the top hole, and then you're good. |
| The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | CSG Mike (09-30-2014), FloridaBRZ (09-29-2014) |
#3 | |
Drives: 2005 Toyota Camry
The fluids needed is in your Owner's Manual.
-alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | JohnJuan (09-30-2014) |
| The Highest Amount of Horsepower | Ghost147 | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-02-2014 06:55 PM |
| Re-fueling Timing and Amount | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 03-15-2014 02:03 PM |
| Ohlins R&T max amount of low (front)? | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-06-2013 06:28 PM |
| Lowest $ Amount Someone Has Thought You Paid For Your FR-S? | DMDominator | Scion FR-S / Toyota 86 GT86 General Forum | 103 | 09-22-2013 08:57 PM |
| Amount of Brake Fluid.... | THEmailman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-13-2013 11:46 PM |
