Old 09-28-2014, 02:38 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Does the FR-S handle any differently with varying fuel loads?
I'm just curious, I'm only on my second car but one thing I've tended to notice was that a full fuel load can cause some cars to perform sluggishly. I've never owned sports cars but I'm sure they wouldn't have an issue..however I wonder how the FR-S handles given it's light weight with a full tank.
Do most of you keep the tank full for the most part?
Spacemane969 is offline   Reply With Quote
Old 09-28-2014, 02:49 PM   #2
I don't notice it as a dd at all. Sure on the track it could make a big difference but they did a really nice job of spreading the weight out at time of design.
Old 09-28-2014, 02:57 PM   #3
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
lol
Obja is offline   Reply With Quote
Old 09-28-2014, 03:18 PM   #4
humfrz
Well, now, ..... the weight difference for the FR-S between a full tank and an almost empty tank is about 70 some pounds.
mrs humfrz weighs 150 pounds (+) ......
I don't notice a performance difference between a full tank and a almost empty tank.
But I sure do notice a performance difference between when mrs humfrz is a passenger or not:
* I can't dump the clutch - cause it will hurt the car!
* I can't rev it up high - cause the engine will blow up!
* I can't take corners real fast - cause it will wear out the tires!
* I can't pass other cars - cause we will crash and die!
So, I just keep the tank pretty much full ....... and .......
humfrz
The Following 17 Users Say Thank You to humfrz For This Useful Post:
86-tundra (09-28-2014), afoust50 (09-28-2014), dchang (09-28-2014), dhuang (09-28-2014), Dr Evil (09-29-2014), Fish Eagle (09-29-2014), fstlane (09-28-2014), G-awesome (09-29-2014), Guff (09-28-2014), JohnJuan (09-29-2014), Kido1986 (09-28-2014), Lonewolf (09-28-2014), michael_king (09-29-2014), richpow (09-29-2014), strat61caster (09-28-2014), Tcoat (09-28-2014), TEWwild (09-28-2014)
Old 09-28-2014, 03:30 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I only notice a difference with passengers...
N1rve
Old 09-28-2014, 03:47 PM   #6
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by Obja View Post
lol
why so funny? People are constantly going crazy on the forums about saving a 10-20 lbs.
1 gallon of gas = 6lbs.
11 gallons of gas = 66lbs
That's a 60 lb difference.
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
Old 09-28-2014, 03:48 PM   #7
86-tundra
Troll Hunter
86-tundra's Avatar
humfrz
10/10 post, this is awesome
The Following 3 Users Say Thank You to 86-tundra For This Useful Post:
humfrz (09-28-2014), michael_king (09-29-2014), richpow (09-29-2014)
Old 09-28-2014, 05:36 PM   #8
strat61caster
strat61caster's Avatar
60-70 lbs. is not insignificant if you're serious, fighting for tenths of a second on a lap or a couple hundreds down a drag strip. Racing teams spend millions optimizing every piece to the minimum it needs to be.
They say it costs $10,000 to put a pound of payload into orbit around our planet.
Will it help you beat a Mustang to the next stoplight? Probably not. Will you feel it in the butt dyno as you floor it through the onramp on your way to work? Probably not. Will the car feel different at the end of a track day vs. the beginning? Absolutely, but that's not entirely due to the fuel burning off as track temperatures change, your tires wear and you either find a better line around the track or your reflexes start lagging.
tl;dr: don't worry about it unless you're racing competitively.
Old 09-28-2014, 06:00 PM   #9
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
No.
Unless you're a race car driver, it's going to be psychological.
I'll say this though. If there is something inside my cabin or trunk that is rolling around, that will f***ing mind-rape me. I loose a good 50hp if there is some piece of sh*t rolling around on the floor. Suspension goes all wonky too and I can't go around a corner to save my life until I get out of the f***ing car and fix it.
NWFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to NWFRS For This Useful Post:
michael_king (09-29-2014), sprintertrueno86 (09-28-2014)
Old 09-28-2014, 06:03 PM   #10
Lonewolf
Lonewolf's Avatar
Drives: Moped
humfrz
Only married men truly understand the depths of each other's pain, lol
Old 09-28-2014, 06:16 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
comin' back from Seaside we had a chance to pass so while i was cookin' it a little, my wife smiles and says "it turns so easily, like you're not even trying."
"i know, right?"
look down <doh!> 97. oops. sorry, officer.
Old 09-28-2014, 06:30 PM   #12
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
The fuel tank is below the lateral CG. This is a relatively light fuel load. Any decrease will improve acceleration and braking. 70 lb is 3% of the total weight of the car. You will notice it if the change is instantaneous like giving a child a ride. In planes, particularly taking off on a hot day at a high altitude airport like Denver, fuel load may be the difference between going and not going. The fuel load can be as high as 50% of the weight of the aircraft. Burning 1000lb on a 17,000lb plane is the difference between going to 43,000ft and 45,000 ft.
I have had a trip out of Lake Tahoe, where if the temp went from 30°C to 31°C determined whether we could come nonstop back to Florida or have to stop in Reno.
It was takeoff performance based on having an engine failure and climbing out on one engine.
The bottom line is the hotter it is and the higher you drive the more that 70lb is going to affect your performance.
John
2013 firestorm FR-S OFT, OFH, U-Haul Trailer Hitch
2007 Stormy Blue Mica PRHT GT NC Miata, OFT
jdcorbitt3 is offline   Reply With Quote
The Following User Says Thank You to jdcorbitt3 For This Useful Post:
86-tundra (09-29-2014)
Old 09-28-2014, 06:30 PM   #13
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Like spare change in cup holder.
sprintertrueno86 is offline   Reply With Quote
The Following User Says Thank You to sprintertrueno86 For This Useful Post:
NWFRS (09-28-2014)
Old 09-28-2014, 07:11 PM   #14
Gunman
Drives: 2019 Mazda Miata RF
Nah, my wife smiles when the tires are squealing, and she's told me it sounds so much better up in the higher rpm range during spirited mountain drives. I don't think she's a unicorn, but it's possible...I have taken her to car shows on our anniversary, and an anniversary trip to the Tail of the Dragon.
Gunman is offline   Reply With Quote
The Following User Says Thank You to Gunman For This Useful Post:
FI Owners: If you were to do it all over again, what would you do differently? campy Forced Induction 46 09-24-2016 11:03 PM
Popping noise at high lateral G-Loads (front of car) ddeflyer Tracking / Autocross / HPDE / Drifting 14 05-24-2016 02:41 PM
My car runs differently now vs. new. Does yours? empower-auto Issues | Warranty | Recalls / TSB 2 07-08-2013 05:26 PM
Oil starvation in high loads jdcorbitt3 Engine, Exhaust, Transmission 7 06-01-2013 10:46 PM
Navigation loads duplicate songs from USB R0ME0 Electronics | Audio | NAV | Infotainment 5 11-28-2012 12:45 PM
