Old 09-25-2014, 06:25 AM   #1
JamesBond000
First Class Speeder
Drives: Silent and Quick
Opinions on this Rear Diff Oil
[ame="http://www.amazon.com/318121-Pressure-Limited-Slip-Differential-Lubricant-2/dp/B004LF1TVY/ref=pd_cart_bxgy_4_p?ie=UTF8&refRID=03R960Q5DGEBDG G4R0HX"]Amazon.com: MOTUL -318121 90 PA Extreme Pressure Limited-Slip Differential (LSD) Lubricant-2 Liter: Automotive[/ame]
I dont even know if this is the right kind just double checking otherwise i planned on using the motul 300 75w90
JamesBond000 is offline   Reply With Quote
Old 09-25-2014, 08:00 AM   #2
Ferrari
Ferrari's Avatar
Drives: Taking the bus
It's a straight weight mineral oil. I wouldn't use it.
Use either Motul Gear 300 or Motul Gear 300LS in the rear diff.
Ferrari is offline   Reply With Quote
IS300 M85/M98 rear diff - does it fit? PantsDants Engine, Exhaust, Transmission 39 03-28-2017 08:28 PM
FBM 8.8 IRS Rear Diff Conversion FullBlown Forced Induction 133 12-26-2015 10:35 AM
Rear diff LSD question Dephective Engine, Exhaust, Transmission 15 09-01-2013 05:30 PM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 10:23 PM
T1R Rear Diff colars ! AJ PwR Engine, Exhaust, Transmission 0 10-09-2012 10:00 PM
