| View Poll Results: What drifting setup do you all run? | |||
| Pedal dance and turn all off |
16 | 22.54% |
| Push the trac off button for 5 seconds |
55 | 77.46% |
| Voters: 71. You may not vote on this poll | |||
Drives: 2014 Monogram FR-S White MT
Proper drifting settings
What is the hooning technique for just busting donuts and drifting in general you run?
Drives: frs
And old FR car
Drives: '24 GR86
Pull the fuse. Gets rid of all the driving aids and won't apply the brakes in a panic situation.
I hate any type of aid, including ABS for drifting.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | Manji (09-22-2014) |
Drives: 2018 BMW M240i
Pulling fuses and pedal dance is overkill for just wanting to drift around for fun.
Holding the trac button works just fine. |
| The Following User Says Thank You to tennisfreak For This Useful Post: | sittinSideways (09-25-2014) |
Drives: FRS
wet the ground with water.
| The Following User Says Thank You to 8R6 For This Useful Post: | amilhazes (09-25-2014) |
Drives: 2005 Toyota Camry
With only pedal dance:
[ame="https://www.youtube.com/watch?v=cGwnf2tyDPA"]BRZ drifting @ Vegas Drift 05.30.14 - YouTube[/ame] -alex |
Señor Member
Pedal dance. With just holding the trac button for 5 secs you can't use the brake and gas pedal at the same time.
| The Following 3 Users Say Thank You to STV3 For This Useful Post: |
#10 |
Hi everybody!
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
#11 |
Señor Member
#12 |
Hi everybody!
Cool just a genuine question, hadn't heard that before. This apply to both hand and foot brakes? I only ask because this is my first stick and now that I've got rev match down shifting handled, I was getting ready to learn heel-toe techniques.
#13 | |
Señor Member
And you don't want to be on the gas while pulling the hand brake BTW. You don't want the trans engaged to the engine at all while pulling the handbrake for that matter. |
| The Following 2 Users Say Thank You to STV3 For This Useful Post: | Demandred7 (09-22-2014), Frishkorn (09-22-2014) |
#14 | |||
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
I tested this exhaustively when I first got the car. Everyone said that pedal dance was all aids off except abs, but my experience was that there's still something that will cut in at high angle. Don't ask me the technical reasoning, because I don't know. All I know is what I experienced, and I also know that the other drift guys I talk to have had similar experiences and don't run the abs fuse either. Here's some vids of me holding the car on full lock through a few sections, all in 3rd gear. Even with pedal dance setting, it would panic at this lock, and it also didn't like lock to lock switches. With the fuse removed it feels like a normal FR car; that's why I never put it back in. [ame]http://youtu.be/4tw7V20iy8M[/ame] [ame]http://youtu.be/k0Hgq_kFj44[/ame] [ame]http://youtu.be/j1upheg_q1Q[/ame] |
| The Following 3 Users Say Thank You to Manji For This Useful Post: |
| Help on a proper setup | Zechs21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 01-07-2014 12:20 AM |
| Proper Intake for 86/BRZ | Martin Donnon | Engine, Exhaust, Transmission | 11 | 10-17-2013 04:49 AM |
| Had my car taken away for a proper detailing. | Nourdmrolnmt1 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 04-15-2013 11:43 PM |
| Proper way to Rev Match | pinoyplaya | Engine, Exhaust, Transmission | 46 | 09-05-2012 01:09 PM |
| A proper test of the FR-S | Vanguard | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 03-19-2012 10:58 PM |
