Drives: Whiteout frs
Powered by MAX Comp Coilover Lower control arm review/Install
Powered by Max Comp Coilover lower control arm install/review
Before (stock suspension) ![]() I started on the rears and since we were installing lca's and coils we took everything off except for the two nuts that hold the coil to the body inside the trunk. ![]() ![]() Lower control arm and rear coil installed. There is two holes to mount the coilover in, top hole is 20mm lower bottom is 45mm lower. I didn't have the balls to try the bottom hole ..... yet ![]() Front stock suspension removed ![]() ![]() ![]() ![]() After install. i plan on going lower but the stock end links up front wouldn't let me. ![]() Everyone told me how stiff and uncomfortable pbm coils were, but I knew they made quality products so I went out on a limb and did it. To my surprise they are nowhere near as stiff as people made them out to be. They are pretty damn comfortable and take dips and uneven roads better than any other coil I've ran before. Ive been on pbm's for about 3 weeks now and i have the the dampening set to 7/12 clicks all around. With this set up you have an insane range of ride height adjustiblity, you can go super super low on these. I have no complaints other than every once in a while you will hear a pop or in the rear at low speeds or on steep inclines. Overall this is best coil over I've owned and I reccomend this set up to anyone looking for a quality set of suspension with out killing your wallet. thanks for looking!!
Drives:
These are on my radar. Glad to see more people starting to run them.
Sent from my KFTHWI using Tapatalk |
Drives: Sapphire Blue ‘23
Been waiting for a review on these coils, makes me even more stoked to pick up a set!
Drives: Whiteout FR-S
How is the camber adjustment in the rear? Is it pretty easy to get to without taking the LCA down?
Drives: Your Car
Did you need rear toe arms to get back to spec?
Sent from my HTC One_M8 using Tapatalk
Are you gonna buy new endlinks so you can lower more?
Daedalus Moto
Hmm I've always loved PBM but was hesitant based on the spring rates. You'll have to keep updating I'd be curious how these hold up with time
#9 | |
#10 | |
#11 | |
Drives: Fr-s
you shouldn't need toe arms for anything under -5 camber in the rear. |
#12 |
Incorrect. Anytime you change camber by using rear lower controls arms it messes with the toe.
-Flickr-
IG @illmattic86 |
#13 |
Drives: Fr-s
#14 | |
Daedalus Moto
Well thats awesome to hear. So would you suggest them as a DD setup with maybe very occasional autox/track/drift? I'm talking like 95% DD ha, have the track bike for the real stuff, definitely building the car for a nice looking DD.
| Tags |
| coilovers, lower control arms, pbm, powered by max, review |
| Voodoo13 Rear Lower Control Arms - Initial Inspection - Install/Review to follow | Travisty75 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 10-23-2016 02:33 PM |
| PA:FS Stance Coilover and Lower control arm (price reduced) | tapsumbongfrs | Brakes, Suspension, Chassis | 11 | 10-13-2014 02:50 PM |
| Powered By max coilovers/lower control arms | keeeefers | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 09-27-2014 11:47 PM |
| Powered by max coilovers/lower control arms | keeeefers | Brakes, Suspension, Chassis | 3 | 08-30-2014 05:52 PM |
| Help with Lower Control Arm install. | DaiTT500 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 01-08-2014 10:56 AM |
