Old 09-16-2014, 03:47 PM   #1
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Dead Side Mirrors
Has anyone had an issue with their side mirrors? Neither of mine can be adjusted using the knob (no movement at all). I don't think its a fuse (as its a shared fuse with the ECU which works fine), but I could be wrong.
milhouse is offline   Reply With Quote
Old 09-16-2014, 03:57 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Have you checked all your fuses?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-17-2014, 12:32 AM   #3
humfrz
So, you did check fuse #1 in the fuse block under the instrument panel ..... ??
humfrz
Old 09-17-2014, 11:01 AM   #4
milhouse
Because Racecar
milhouse's Avatar
humfrz
Hmm. I didn't think it was fuse 1 - i think it was 10 per the manual (but maybe that was the problem). But as that (1) fuse is shared with the ECU, I assumed a working ECU would indicate the fuse is fine. It would be nice if the interior fuses didn't require a panel remove...
Old 09-17-2014, 11:18 AM   #5
humfrz
hmmmm........the manual for my 2013 FRS shows the position #1 (a 10 amp fuse) in the fuse block under the dash, controls the main body ECU and the outside rear view mirrors.
Yep, it's unlikely that is the problem (because it's a shared fuse with the main body ECU (whatever that is), but I'd check it anyway (a mirror helps ....)
humfrz
Old 09-20-2014, 05:06 PM   #6
milhouse
Because Racecar
milhouse's Avatar
humfrz
It the fuse. Strange that ecu was fine but the mirrors weren't.
The Following User Says Thank You to milhouse For This Useful Post:
humfrz (09-21-2014)
***Rexpeed Convex Side Mirrors and Carbon Fiber Side Mirror Covers*** FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 249 12-07-2015 01:28 PM
New side mirrors -- now what? FerraraZ Cosmetic Modification (Interior/Exterior/Lighting) 2 10-24-2013 11:44 AM
FS: FRS (oem) Side Mirrors (pair) NRG x FRS Exterior Parts (Aero, Lighting, Etc.) 4 05-06-2013 12:34 AM
Removing side mirrors? GodSays DIY (Do-It-Yourself) Guides 6 03-12-2013 11:04 AM
Entire Drivers Side Electrical Panel completely dead Asphalt~86 Issues | Warranty | Recalls / TSB 13 11-14-2012 02:08 PM
