Old 09-15-2014, 06:32 PM   #1
JARE_ee
Alaska Roll Lover
JARE_ee's Avatar
Drives: Blue.Series.Aozora
Whats the best $1500 Suspension?
Hello everybody,
What would be the best setup to get if you only had 1500 max to spend on suspension. This is my daily driver, and i won't be tracking my car. Cant justify spending 2-3 g's on coilovers.
I just would like maybe 1-1.5 MAX drop (probably 1" or so due to all the bumps in my area)
Main Goals:
Close a bit of the wheel gap
really really comfrontable ride.
Under $1500
Would coilovers be the best option, if so which one?
Thanks!
JARE_ee is offline   Reply With Quote
Old 09-15-2014, 06:40 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
If it's all for looks (no track), then springs and perhaps some camber bolts would suffice. New shocks if oem ones are worn out.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-15-2014, 06:53 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Racecomp Engineering Yellows, and Whiteline 14mm camber bolts.
You loose a touch of compression travel, but the ride is actually better than stock with the included bump stops. The drop is 3/4 of an inch, not much but it looks good without sacrificing to much geometry.
You also get some camber adjustment in the front which should be included in any suspension.
Old 09-15-2014, 07:01 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'd probably add to that some B8's.
Old 09-15-2014, 07:06 PM   #5
jdmblood
jdmblood's Avatar
Drives: white subaru brz
st coilovers are definetly the best dd coilover option out there and lower the car up to 2". those coilovers get great reviews. im pretty sure they go for around 700 and then you can buy lcas to be able to adjust the camber in the rear and thats pretty much all you need.
p.s spc lcas run around 200 bucks so itll be 900 for the setup and then 80 bucks or whatever for an alignment
jdmblood is offline   Reply With Quote
Old 09-15-2014, 07:31 PM   #6
FR-S Matt
Spend about $300 more then get V3's. Trust me, it's worth it. Way more than any of these $800-$1500 ones.
Old 09-15-2014, 07:45 PM   #7
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I went with Hotchkis Camber plates + Camber bolt combo (got -3 in the front, could go more), ST coil overs and SPL rear LCA (-3.5 R). That's a little over $1500 but am satisfied so far.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 09-15-2014, 07:53 PM   #8
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Listed in order of price and quality.
ST Suspensions Coilovers (KW) - $845
Pros: Supplant and planted ride, incredible value.
Cons: Galvanized steel construction not good for salted roads. No rebound adjustment.
Bilstein B14 PSS Coilovers - $1099
Pros: High quality monotube shocks with progressive rate coil spring will provide incredibly comfortable coilover ride for the street.
Cons: Larger diameter springs will limit wheel width more than other coilovers. No rebound adjustment. Progressive spring not suited for competitive driving.
Fortune Auto 500 Coilovers - $1199
Pros: Digressive piston technology provides smooth ride over road imperfections but planted & confident performance when corning. Rebuild-able and 5 yr warranty. 24 point rebound adjustment. Hand built in USA. FT86speedfactory has had lots of success with race car running Fortune Autos.
Cons: For best performance should upgrade with swift spring option and radial bearing.
ST Suspensions TA Coilovers (KW) - $1428
Pros: KW suspension technology at economy pricing. Extra coating to protect galvanized steel. Rebound adjustment.
Cons: Mono-tube design rather than twin-tube like KW.
Coilover options available via FT86SpeedFactory
http://www.ft86speedfactory.com/susp...5e94b888831d1d
*Disclaimer, I have Fortune Auto 500's and love them. The ride is amazing for street, autocross, and canyon carving. Had the ST Suspensions TA Coilovers been available when purchasing, I may have gone with them.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 09-15-2014, 07:58 PM   #9
mwjcyber
mwjcyber's Avatar
Best deal I could find for KW V3 was $1954, which is $454 more than OP stated. But if available for less than that, I would concur for money they are hard to beat.
Old 09-15-2014, 08:01 PM   #10
FR-S Matt
$1820 for me through a vendor. Shop around and PM.
Old 09-15-2014, 08:18 PM   #11
vc86
Drives: 2014 FRS
I got RSR sports-i for sale for $1500
Used for less than 2000 miles.
PM me if interested.
vc86 is offline   Reply With Quote
Old 09-15-2014, 08:45 PM   #12
CSG David
CSG David's Avatar
Originally Posted by JARE_ee View Post
Hello everybody,
Main Goals:
Under $1500
Thanks!
TEIN Street Basis
ST Suspension
Use the rest of the money towards alignment (bolts + LCA?), tires, brake pads, and/or gas.
Old 09-15-2014, 08:53 PM   #13
Model Citizen
Lacking brains
Drives: frz
my v3 were 1760ish shipped last year, but it was luck with stacking a sale and a 10% holiday coupon
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 09-15-2014, 09:05 PM   #14
DAEMANO
Time Traveller
This trumps everything else mentioned in the thread for $1500.
Eibach Multi PRO R2 Coilovers: $1500 FRSdrive Brakes, Suspension, Chassis 11 02-24-2014 07:00 PM
FS: Eibach Multi Pro R2 Suspension $1500.00 FRSdrive Exterior Parts (Aero, Lighting, Etc.) 1 12-24-2013 05:42 PM
$1500 budget coilover - what would you choose? smbstyle Tracking / Autocross / HPDE / Drifting 27 11-17-2013 09:35 PM
