Old 09-14-2014, 11:52 AM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Does an OFT tune clear out any changed TPMS id's
I have a set of summer wheels on now with TPMS sensors. I flashed the new sensor IDs to the ECU using TPM QuickSet. I flash an OFT tune yesterday with EcuFlash and this morning (first time turning on the car) my TPMS light is on. Did this clear out the codes that I wrote? Or is a tire actually low on psi?
Old 09-14-2014, 12:46 PM   #2
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Check the pressures first....And if all good I would relearn the TPMS's
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 09-14-2014, 12:52 PM   #3
Shady195
Drives: '13 10 Series FRS #1203
Would have made sense to check the pressure before starting this thread, then you would have had your answer
Shady195 is offline   Reply With Quote
Old 09-14-2014, 01:31 PM   #4
B-R-Z
B-R-Z's Avatar
Yes, I know. The problem was I couldn't find my pressure checker so I tried to get a quick answer here. I drove to autozone to get a checker and all pressures are at about 31 psi. It is cooler than usual today so maybe that's why it's showing now. Not sure if it is low enough to trigger the light or not though, I will top them off and reflash tpms ids if I have to.
Old 09-17-2014, 02:23 PM   #5
sprintamx
My TPMS sensor light came on after flashing V2.06. Did not come on after flashing V2.01, or any earlier tune. And, yes, pressures are all fine.
Strange.
sprintamx is offline   Reply With Quote
Old 09-17-2014, 09:57 PM   #6
skidmark86
I had a dealer update my TPMS back in April when I put some new rims on with my summer tires. I immediately get back and flash using OFT thinking nothing about the fact that it might override the TPMS update. I haven't had any issues since then and the tire pressure seems to be fine (with no TPMS light).
skidmark86 is offline   Reply With Quote
Old 09-17-2014, 10:10 PM   #7
B-R-Z
B-R-Z's Avatar
I reflashed TPMS ids before I even checked pressure since it takes like 30 seconds. I then bought a pressure checker and found all wheels @ 31 psi. Topped them all off and the light went off. So I'm thinking a flash does not overwrite this part of the ecu.
Old 09-19-2014, 09:04 AM   #8
bfrank1972
Drives: 2013 FR-S Argento
I was under the impression tpms was a completely different system in the car (which is why tuners can't turn off the warning light with software).
bfrank1972 is offline   Reply With Quote
Old 09-19-2014, 09:09 AM   #9
B-R-Z
B-R-Z's Avatar
You may be right, all I know is my TPMS flashing tool connects at the obd2 port so i assumed ecu...but that doesn't mean it's only communicating with the ecu, right?
Any body have ebaich springs, tpms sensors, clear side marks, or white shark attena Anthony7515 Want-To-Buy Requests 2 07-06-2014 07:28 PM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 09:11 AM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
Can DBW tables be changed via Ecutek tune??? Norkoastal Engine, Exhaust, Transmission 1 09-11-2012 07:51 PM
