Old 09-12-2014, 03:19 PM   #1
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Plus1 sizing, or ???
I replaced my stock wheels with 17x7.75", +40. Now it's time to shop for tires (debating using my Primacy's though I'd prefer not to)
Since the rim is a bit wider than stock, should I go up a size in the tire? I'd like to keep a square setup. (front & back the same)
I'm likely going with Pilot SS. I'm running stock suspension.
Would a 225/45 tire on a 7.75" wide rim give me the same height as a 215/45 tire on a 7" wide rim?
I realize actual tire dimensions vary by tire model.
ashtray is offline   Reply With Quote
Old 09-12-2014, 03:27 PM   #2
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
225/45/17 is +1.6% difference
225/40/17 is -2.0% difference
245/40/17 is +.4% difference(which is why you see so many people run them)
according to this http://tire-size-conversion.com/tire-size-calculator/
wheel width should not change it much if at all
G-Man is offline   Reply With Quote
Old 09-12-2014, 04:57 PM   #3
ashtray
Thanks! I wasn't sure if the wider wheel would "stretch" the tire a bit outwards and thus lower the height.
Will probably stay with 215's, as a 245 is wider than I need/want. (I like the lighter feel of a more narrow tire.) Now the only question I have for myself is to go back to the Primacys (in my garage, 6k miles) or spend $$$ on something more sticky.
The Ventus I bought used with the rims are so worn out the back end slides around more with TC full on than the Primacy's did in Sport mode - and that's saying something! It's like driving in the rain all the time, except its 85 degrees and sunny out.
Old 09-12-2014, 06:37 PM   #4
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Probably not. See: http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Super+ Sport&tab=Specs. But it will be awfully close - I'd guess 24.7 vs. 24.9
dradernh is offline   Reply With Quote
XXR 527 sizing questions g0lden Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-16-2015 01:10 PM
DRL Bulb Sizing.. bhbnuckle Cosmetic Modification (Interior/Exterior/Lighting) 12 06-13-2014 12:10 PM
Sizing comparisons? rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-17-2013 01:47 PM
RTR tire sizing SVThis Tracking / Autocross / HPDE / Drifting 10 02-19-2013 08:10 PM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 08:15 PM
