Old 09-12-2014, 11:21 AM   #1
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
UEL oe EL header for Autocross
Hi, I'm planning in getting a header but I dont know what should be better for autocross... An UEL Header (more torque and low to midle rpms) or an EL Header (more peak power and high top rpms)...
Helppppop
Toyota GT 86 is offline   Reply With Quote
Old 09-12-2014, 11:24 AM   #2
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
never Autox before but I would imagine being in 1st and 2nd gear a lot and all over the place in the rpm range. I would go with UEL but definitely would like to know what someone with Autox experience suggests.
BoxRZ_86 is offline   Reply With Quote
Old 09-12-2014, 11:26 AM   #3
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
EL usually produces better torque gains in any point of the rev range. HKS, JDL, PTuning and Nameless are the competitive headers.
raul is offline   Reply With Quote
The Following 2 Users Say Thank You to raul For This Useful Post:
forwallblakmail (09-17-2014), Toyota GT 86 (09-12-2014)
Old 09-14-2014, 01:38 PM   #4
markw
Drives: 2014 FR-S
Have you autcrossed before? Money would be better spent on tires, wheels, suspension tweaks. More power helps, but not as much as suspension.
markw is offline   Reply With Quote
Old 09-14-2014, 01:44 PM   #5
xwd
The only place where the UEL makes more torque is at very low RPM, but the reality is either one will work.
The top few guys running STX at Nationals are using different types from different manufacturers... The header isn't going to make or break you winning or losing.
Old 09-15-2014, 12:03 PM   #6
Toyota GT 86
Already have tyres wheels suspension exhaust.... Just missing the header
Old 09-15-2014, 05:57 PM   #7
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I agree, header+tune last, everything else will help more until you finish them!
That said I a supremely excited for my UEL JDL header, catted overpipe and front pipe for next year...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 09-15-2014, 06:13 PM   #8
nyfries
Drives: 14 FRS Whiteout
Non. Either will bump u into a class you won't have much fun in or close to being competitive in. Stay as stock as possible for your first few times. Than tires camber suspension, should be able to do the above while staying in the c stock or maybe c street class
Sent from my iPad using Tapatalk HD
nyfries is offline   Reply With Quote
Old 09-15-2014, 07:49 PM   #9
EL.
You have no business being in that low an RPM range at AutoX.
raul (09-16-2014), wparsons (09-16-2014)
Old 09-15-2014, 08:20 PM   #10
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
EL.
Seems to me that one would have a much better shot at staying within the power band on a road course or the street, more so than an autoX course. On most local events I've been to, it's pretty much 1st to 2nd, then stay in second. There are plenty of times when I'd rather be a gear down, but shifting would cost more time that just staying in 2nd. This car can really use the mid-range torque. I doubt that having either a EL or UEL is going to make or break a driver's competitiveness in autocross. If I was building a dedicated road course car, I'd get an EL header.
I might be wrong about all that.
Thrustin is offline   Reply With Quote
The Following User Says Thank You to Thrustin For This Useful Post:
tahdizzle (09-16-2014)
Old 09-16-2014, 11:09 AM   #11
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I don't know what the flat-foot shifting is like with Ecutek, but the time down shifting then up shifting again, for me anyway, I might as well have just stayed in 2nd.
-Jack Burton
Old 09-16-2014, 01:52 PM   #12
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I have a JDL UEL.
Rarely even would you need to go back to first. As far as flat shifting, I wouldn't bother unless the wheel is dead straight as you will usually be shifting while setting up or entering a turn.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 09-16-2014, 01:54 PM   #13
STV3
Señor Member
STV3's Avatar
Which ever you think sounds better.
STV3 is offline   Reply With Quote
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
