Old 09-07-2014, 02:42 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Power expectations with catless UEL/ABE/k&n filter on OFT UEL stg 2
Trying to decide if I should get a OFT. My mods are listed in the subject and I do not plan to get anything else. Has anyone done a dyno run with my similar mods and a OFT stage 2 UEL tune (on 93 oct)? Just trying to see if its worth the expense.
Old 09-07-2014, 03:28 PM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I have the OFT Stage 2 UEL 93 Octane tune running on my car with a catless header and full exhaust. Will be going to the dyno later on this week.
malubawla is offline   Reply With Quote
The Following 4 Users Say Thank You to malubawla For This Useful Post:
B-R-Z (09-07-2014), BoostedWrbBrz (09-14-2014), flippy (09-09-2014), troek (09-07-2014)
Old 09-07-2014, 04:33 PM   #3
steve99
About 20 rear wheel hp over stock add E85 and make the about 30 rwhp
http://www.ft86club.com/forums/showthread.php?t=55450
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Darkparadox911 (06-16-2015), lucid215 (09-08-2014)
Old 09-07-2014, 05:07 PM   #4
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The OFT will make a bigger difference to how your car runs than your header. Used with a header, it will wake things up in a very big way. I don't think I have every met anyone who felt their money was wasted. Usually I hear "I should have done it sooner"
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
CamryDS (09-09-2014), Darkparadox911 (06-16-2015), flippy (09-09-2014), lucid215 (09-08-2014)
Old 09-07-2014, 06:36 PM   #5
jupillam
jupillam's Avatar
Drives: White out Scion Frs
Yeyep. I was skeptical at first with OFT and all, but after biting the bullet and ordered OFT. After running E85 for sometime now, I cant find a single reason to go back to stock.
jupillam is offline   Reply With Quote
The Following 2 Users Say Thank You to jupillam For This Useful Post:
Darkparadox911 (06-16-2015), Shiv@Openflash (09-09-2014)
Old 09-08-2014, 06:42 AM   #6
troek
troek's Avatar
Drives: 2012 Toyota 86
Best 500 bucks besides tires you could spend on this car. And that is debatable if ur not tracking your car as twisties on stock tires is a blast.
The Following User Says Thank You to troek For This Useful Post:
Old 09-09-2014, 11:04 AM   #7
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
After the flash, my idle is very smooth, and the power delivery is much more linear. Pulls alot harder in the mid range towards redline.
Darkparadox911 (06-16-2015), dhuang (10-26-2014), lucid215 (09-09-2014), Shiv@Openflash (09-09-2014)
Old 09-09-2014, 11:29 AM   #8
lucid215
im running the oft stage 2 uel and i have ofh, over pipe, front pipe, axle back, and intake. the car definitley pulls alot harder then she did stock. i wanna go to a dyno just to see what im putting down. e85 is a lot more fun haha
lucid215 is offline   Reply With Quote
Old 09-09-2014, 11:43 AM   #9
smbstyle
smbstyle's Avatar
Stock: 162 hp / 134 tq (Dynojet)
185 hp / 149 tq with Stage 2 UEL OFT canned tune, RevWorks UEL header, stock OP, DC uncatted front pipe, stock catback, HKS drop-in with modded snorkel.
I then had a very reputable shop dial in the OFT tune a bit, and ended up with 191 hp / 156 tq.
Nothing wrong at all with the OTS tune, it was fantastic, but the car spends it's life on track, so I wanted to make sure everything was spot on.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following 3 Users Say Thank You to smbstyle For This Useful Post:
Shiv@Openflash (09-09-2014), troek (09-09-2014), Wayno (09-22-2014)
Old 09-09-2014, 12:50 PM   #10
B-R-Z
B-R-Z's Avatar
I guess peak numbers aren't the big seller here. I am trying to decide if spending $500 for the OFT will make the car THAT much better/funner to drive. The extra 10 hp gained doesn't look all that attractive to me for the cost.
Old 09-09-2014, 12:52 PM   #11
jvincent
jvincent's Avatar
Yes it will.
All I have is an OFT and drop in filter and the car just drives so much better.
Don't bother with any exhaust non-sense unless you need noise and looks. The header will help to remove the torque dip and add some more power but even without the head it is still worth it.
Old 09-09-2014, 01:07 PM   #12
B-R-Z
B-R-Z's Avatar
What does drives better mean though, how so.
Old 09-09-2014, 01:25 PM   #13
Shiv@Openflash
Drives: 2013 FRS
Smoother. More responsive. None of the dead spots that exist with the stock tune. Much less of a torque dip. Smoother idle. More power up top. Revs more freely.
Those are the most fitting adjectives I could come up with before having my morning coffee.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
flippy (09-09-2014)
Old 09-09-2014, 01:42 PM   #14
jvincent
jvincent's Avatar
@Shiv@Openflash described it pretty well.
I've had an OFT since last October. Best $500 spent on the car hands down.
Expectations/Needs to Switch to E85 on a Supercharger Pneub Forced Induction 9 07-19-2013 03:54 PM
MPG expectations? FR-S and BRZ Mino Engine, Exhaust, Transmission 80 03-04-2012 08:48 PM
Interior Expectations Archer256 Scion FR-S / Toyota 86 GT86 General Forum 57 03-31-2011 03:28 PM
