Old 09-06-2014, 06:19 PM   #1
LALFAN
Drives: FR-S RS 1.0
TRD Sway Bar Kit... comfort?
I'm curious if the TRD Sway Bar Kit would be better or worse for ride comfort? Ultimately I understand this a performance type upgrade, but I'm wondering how it would change the ride characteristics, specifically in conjunction with the TRD Lowering Springs.
This would mostly be a daily driven car so if it's going to adversely affect the comfort it's probably not something I would consider.
How about maintenance down the road, are there parts associated with the kit that would need to be replaced, like bushings? Expected life?
Thanks!
LALFAN is offline   Reply With Quote
Old 09-06-2014, 07:13 PM   #2
Createddeleted
Drives: 2014 BRZ - 2004 GLI
I daily drove mine and my girlfriend never knew I installed them. That said, great upgrade. You'll only notice a little discomfort over heavily uneven road / taking speed bumps at an angle.
Maintenance wise? Lube the bushings every now and then. Might need to replace bushings waaaay down the road.
*i was on stock springs*
Createddeleted is offline   Reply With Quote
Old 09-06-2014, 08:29 PM   #3
CSG David
CSG David's Avatar
No difference in ride quality.
Old 09-07-2014, 04:05 AM   #4
arvidj
Drives: '93 MR2 Turbo
Anyone have a suggestion for lubricant?
I have a new 2015 with the dealer installed TRD sway bars. I know they lubricated the bushings when they installed the bars but there is an annoying squeak when the car comes to a stop ... as in that last 10th of a second when the suspension unloads after the car has stopped. I'd like to re-lubricate them but have no idea what to use.
Thanks,
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
Old 09-07-2014, 11:30 AM   #5
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
You can use something like this: http://www.summitracing.com/search/p...d-individually
The bars sold by Hotchkis have Zerk fittings, and they sell this to put in a grease gun: http://www.hotchkis.net/14_oz_super_grease.html
Prothane Super Grease is popular with some off-road guys due to the mud, water, etc. they have to go through, and they also make a 14 oz. tube to go in a grease gun: http://www.amazon.com/Prothane-19-1751-Super-Grease-Tube Given the same name, I wonder if Hotchkis' Super Grease is sourced from Prothane.
dradernh is offline   Reply With Quote
Old 09-14-2014, 03:02 PM   #6
BRZ NA
Drives: WR blue
How does it performance compare w other brand like whiteline...?
BRZ NA is offline   Reply With Quote
Seat Bolsters and Comfort krulux DIY (Do-It-Yourself) Guides 22 07-21-2017 09:33 AM
KW Street Comfort Jerf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-28-2014 08:51 PM
Stance C/O comfort pmccut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-27-2013 06:27 PM
Comfort for everyday use... Are you pleased ? Mikem53 Scion FR-S / Toyota 86 GT86 General Forum 69 04-14-2013 11:30 PM
Driver Comfort Concerns Audi Scion FR-S / Toyota 86 GT86 General Forum 9 01-02-2012 09:52 PM
