Old 09-03-2014, 11:53 AM   #1
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
j2 quad exhaust questions
i recently installed a j2 quad exhaust and I'm experiencing backfire at high rpms. anybody else experiencing this. I do have a catless front pipe attached but i checked my logs and my a/f ratio is anywhere between 12.2-12.5 open throttle which i don't think is bad. another thing is my exhaust is super loud, nothing like what i hear in videos. its super loud no matter what rpm i am in, just wanted to know what setups people are running with the quad and is it super loud even when cruising? thank you for the help
brichard0625 is offline   Reply With Quote
Old 09-03-2014, 12:14 PM   #2
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
The J2 Quad is 2.75 piping, its gonna be LOUD. Especially with a test pipe. Im dealing with this right now with my setup. It's a love/hate ordeal. I may try running a resonated front pipe to see if that tames it a little. Looks at the CNT Racing front pipe, it looks like a good deal.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 09-03-2014, 12:16 PM   #3
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
catless front pipe will cause it to be loud. Do you have a resonator? or is it a straight pipe?
Backfire is likely from low afr + no cat. I'm assuming you only get it when you're pushing the car, and it's not backfiring at idle or something ridiculous like that right? Unused hot fuel + fresh air = backfire. No way around that unless you put in a cat.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-03-2014, 01:23 PM   #4
brichard0625
thanx for the help guys. I knew the front pipe would make it loud, but it was crazy loud, I felt something was wrong. It was backfiring at high rpms now at idle. I just went underneath the car and did the soapy water leak test to find that my front pipe underneath the car was leaking. I used the old bolts from the pipe and i found that one of them did crack and caused that pipe to not be sealed properly to the midpipe. exhaust sounds much much better now, still loud but if could hear what it sounded like before was crazy. thanx for the help guys
Old 09-04-2014, 02:04 AM   #5
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
You get used to it. It'll quiet down after a while. But I love it.
Pooverdam is offline   Reply With Quote
Old 09-04-2014, 01:36 PM   #6
Covo_86
Covo_86's Avatar
Drives: Whiteout FRS
where did you get your j2 quad ? Every website is out of stock
Covo_86 is offline   Reply With Quote
Old 09-05-2014, 12:16 AM   #7
Pooverdam
Pooverdam's Avatar
Redline360 dot com
Quad Tip Exhaust -Ozzy- Engine, Exhaust, Transmission 16 01-23-2016 07:18 PM
TRD Quad Exhaust questions Recoils14 Engine, Exhaust, Transmission 3 11-22-2014 03:27 PM
J2 quad tip exhaust TheGuyWithTheFireStorm Engine, Exhaust, Transmission 0 11-25-2013 06:34 PM
WTB: J2 QUAD EXHAUST AG3NT_5CARFAC3 Engine, Exhaust, Bolt-Ons 8 08-17-2013 07:02 PM
Questions about the j2 quad tip exhaust Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 3 06-29-2013 06:01 PM
