Old 08-30-2014, 11:20 AM   #1
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Rear Diffuser with No Exhaust Holes
Hey guys
i searched but could not find anything other than the FT86 Speedfactory deletes but was wondering does anyone know of or make a rear diffuser for this car that blocks off BOTH exhaust holes?
Reason why...
PrimeMotoring is offline   Reply With Quote
The Following 2 Users Say Thank You to PrimeMotoring For This Useful Post:
raven1231 (08-30-2014), ZionsWrath (08-30-2014)
Old 08-30-2014, 12:40 PM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Contact Carl at http://drivewaylabs.com/. He made an exit block thing to cover the hole if I remember correctly. Plus he makes better diffusers.
stockysnail is offline   Reply With Quote
The Following 3 Users Say Thank You to stockysnail For This Useful Post:
Ammonia (08-30-2014), PrimeMotoring (09-01-2014), ZionsWrath (08-30-2014)
Old 08-30-2014, 12:47 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Damn your car
It's like stealth but not stealth at the same time
And you have the same scratch from the license plate that I do.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 08-30-2014, 12:48 PM   #4
gramicci101
Off Topic
Just curious, how are you going to avoid sucking rocks, birds, or small children into your turbo?
You could probably cover the holes with fiberglass. If you wanted to go all out you could sand the slight lip around the holes down and make it a smooth curve.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Anthony (09-01-2014), ZionsWrath (08-30-2014)
Old 08-30-2014, 12:53 PM   #5
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Speed factory is selling the DWL diffuser, but you are correct that Carl is the guy to speak with. There is a guy local here in AZ that has very similar diffuser, but it has not been aero tested to my knowledge and I don't know he has exhaust exit blocks as he is using his.
The fabrication work for a block isn't terribly hard to do, I would bet, but I am using a dual exit set up.
The Following 2 Users Say Thank You to Celadrielas For This Useful Post:
Old 08-30-2014, 12:53 PM   #6
MrBlaze-65
Drives: 2014 Subaru BRZ
speedfactory makes a block off for both left and right.
http://www.ft86speedfactory.com/exha...le-covers-215/
MrBlaze-65 is offline   Reply With Quote
The Following 2 Users Say Thank You to MrBlaze-65 For This Useful Post:
Old 08-30-2014, 01:10 PM   #7
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Cut it out entirely
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following 7 Users Say Thank You to Wonderbar For This Useful Post:
8R6 (09-01-2014), Nsot (08-30-2014), PrimeMotoring (09-01-2014), s2d4 (08-30-2014), Struckbylitenin (08-30-2014), Travisty75 (08-30-2014), ZionsWrath (08-30-2014)
Old 08-30-2014, 01:33 PM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Wonderbar View Post
Cut it out entirely
@Anthony
ftc~brz (09-02-2014)
Old 08-30-2014, 04:31 PM   #9
Poodles
Drives: 2015 Series.Blue
Cut it out entirely
This. Without the muffler there it's just going to act like a parachute.
The Following User Says Thank You to Poodles For This Useful Post:
Old 08-30-2014, 05:51 PM   #10
Wonderbar
Driveway labs.
Wonderbar's Avatar
I'd still add a diffuser, but I'm not trying to thread jack.
The Following 2 Users Say Thank You to Wonderbar For This Useful Post:
gramicci101 (09-01-2014), Gunman (08-30-2014)
Old 08-31-2014, 08:20 AM   #11
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
is that the downpipe and the wastegate exhaust im seeing on the hood? oh man, that's gonna be loud.
Yamajee is offline   Reply With Quote
Old 09-01-2014, 11:18 AM   #12
PrimeMotoring
We have a mesh screen around the inlet to prevent larger things like children from becoming precision stew
The Following 3 Users Say Thank You to PrimeMotoring For This Useful Post:
ftc~brz (09-02-2014), gramicci101 (09-01-2014), ZionsWrath (09-01-2014)
Old 09-01-2014, 11:19 AM   #13
PrimeMotoring
Cut it out entirely
Seems like this will be the inevitable route
The Following User Says Thank You to PrimeMotoring For This Useful Post:
Old 09-01-2014, 11:21 AM   #14
PrimeMotoring
Yes, its loud at startup and under wot but cruising and putting around is surprisingly docile. Just a very loud whistle lol
Does the oe style rear diffuser fit with an invidia n1 exhaust? Andre da gr8 Cosmetic Modification (Interior/Exterior/Lighting) 3 07-18-2014 05:10 AM
*Lowest prices on Borla Exhaust, Mid-pipe, Headers, & Rear diffuser AJUSA.com Engine, Exhaust, Bolt-Ons 34 12-04-2013 01:22 PM
Rear Fender holes- are screws missing here? Coolhand BRZ First-Gen (2012+) — General Topics 11 10-30-2013 03:28 PM
There are holes when Debadging the rear Logo! enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 4 10-15-2012 12:30 PM
Holes in rear arches lordgrover Scion FR-S / Toyota 86 GT86 General Forum 26 09-13-2012 12:47 PM
