Old 08-28-2014, 09:54 PM   #1
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
DIY Racer X Master Cylinder Brace + review
Tools:
10mm socket
13mm open wrench
#4 hex key
small flat head
Remove the plastic holding the fuel line together.
With a 10 mm socket remove the bolt holding the bracket.
Remove sticker.
Now you are ready to install the MCB.
Note where you are going to put the new bolts.
Make sure you re-install the bracket before putting in the bolts.
tighten both bolts down.
Adjust if needed.
Finished
Review:Installation was breeze. Install link here:[ame="https://www.youtube.com/watch?v=gdm24Jqiptg"]How to install Racer X Fabrication Master cylinder Brace BRZ FRS GT86 - YouTube[/ame]
The design is clean. Craftsmanship and finish is pretty much an art. In addition, the brace is very light weight because the brace is billet Aluminum. (for the people who do not know what billet Aluminum is…They start with one solid piece of aluminum and machine around it to make the shape / part)
Cost is priced the well compared to other MCB in the market. However, it has said before you get what you paid for. I believe that this master cylinder brace is the best money can buy.
Does it work?
With daily driving my test buddy could not even tell that I had anything done to it. However, with heavier / hard brakes YES! He was able to tell a positive difference and the pedal did feel more responsive.
Was it worth it?
Yes, at 89 may seem a lot, however if you compared that to two tank fill up here in Maryland 89 bucks is pretty much nothing. It was a clean, simple, and fun modification to do.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 08-28-2014, 10:15 PM   #2
Knshro13
Drives: 10 series FRS
Nice review. I noticed mine right when I got on the brakes the first time. Even at low speed, light braking. It's a huge upgrade for such a small price. Well worth it, in my opinion.
Knshro13 is offline   Reply With Quote
Wtb grimmspeed master cylinder brace. CamryDS Want-To-Buy Requests 2 07-22-2014 06:48 PM
Master brake cylinder brace Ryan86 AFRICA 42 02-10-2013 02:47 AM
BRZ/FR-S master cylinder brace - $60 Turn in Concepts Brakes, Suspension, Chassis 35 01-26-2013 12:17 PM
Perrin master cylinder brace SubaSteve Brakes, Suspension, Chassis 9 01-11-2013 10:46 PM
