Old 08-26-2014, 06:27 AM   #1
jsc1234
Enkei RPF1 17x9 +45
This is my lightest wheel and first non-Rota wheel.
17x9 +45
225/45/17
KW V3 Coilovers (so far no rubbing at full lock)
jsc1234 is offline   Reply With Quote
The Following 3 Users Say Thank You to jsc1234 For This Useful Post:
Brinks (08-26-2014), D_Thissen (08-26-2014), SkAsphalt (08-26-2014)
Old 08-26-2014, 06:52 AM   #2
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
Those look great man!
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 08-26-2014, 10:01 AM   #3
Smoke Destructer
Drives: 2013 Whiteout FRS
Camber specs?
Smoke Destructer is offline   Reply With Quote
Old 08-26-2014, 07:34 PM   #4
jsc1234
Originally Posted by Smoke Destructer View Post
Camber specs?
no camber
Old 08-26-2014, 07:43 PM   #5
vroom4
Which brand lip and skirts? They look like they fit very well!
vroom4 is offline   Reply With Quote
Old 08-27-2014, 11:29 AM   #6
AutoRnD
AutoRnD's Avatar
Drives: Fast ones
KW lower mounting point has an elgonated/slotted hole so you can adjust camber at the lower mounting point up front.
Just FYI.
Make sure you get an alignment done and let them know camber can be adjusted at this position in the event you don't have camber plates. If not set near symmetrical it might also affect your caster.
AutoRnD is offline   Reply With Quote
Old 08-27-2014, 12:23 PM   #7
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Just curious why only a 225 on a 9" rim?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 08-27-2014, 12:40 PM   #8
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
sexy brz, you won't rub on 245/40 either.
adprokid is offline   Reply With Quote
Old 08-27-2014, 08:49 PM   #9
RC51rydr
RC51rydr's Avatar
Drives: 2014 BRZ Limited
Look real good man! Going in the same direction eventually.
2014 Subaru BRZ SSM Limited
2006 Inifinit G35x AWD
2003 Suzuki GSXR 1000 K3
1983 Kawasaki KZ750H2 LTD
RC51rydr is offline   Reply With Quote
Old 08-27-2014, 10:58 PM   #10
jsc1234
STI Rep Front lip and chargespeed side skirts
i had 17x8 rims before this with the 225. they still had about 50% left on em so i just put em on these rims til they run out.
nice thanks! planning to get 245 on my next set
FS: Enkei RPF1 17x9 +35 w/PSS (WI) wgnzlz Wheels and Tires 9 06-18-2014 06:10 PM
PA:WTB/FT black enkei raijin 18x8.5 18x9.5 for enkei rpf1 17x9 SterlingBrz Wheels and Tires 1 05-28-2014 11:36 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
17x9 Enkei RPF1's now available! UncleFester Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 02-09-2013 05:34 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
