Old 08-21-2014, 08:18 PM   #1
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Need a new router
Hello fellow car enthusiasts,
I need a new router because the WiFi radio in my current one is dying. Problem is, I stopped caring about computer hardware a couple years ago, and every time I go to shop for a new one online, I become bored and flaccid.
Here are my requirements:
-Under $200
-DD-WRT compatible
-Fast but doesn't need to be insane.
-No D-Link or TP-Link, they don't last
That's about it. TIA for your help.
pushrod is offline   Reply With Quote
Old 08-21-2014, 08:48 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
I'd suggest a Porter-Cable, but then I read "wifi" so never mind...
Gunman is offline   Reply With Quote
The Following 2 Users Say Thank You to Gunman For This Useful Post:
hypercarfanatic (08-25-2014), jebuwh (08-21-2014)
Old 08-21-2014, 08:55 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
I would get this one: Linksys WRT1900AC, but you need to raise your $ by $50.
http://www.bestbuy.com/site/promo/li...-router-119985
Main reason is that it has USB ports & eSata so you can plug an external drive into it and you have an instant wireless NAS drive.
Old 08-21-2014, 10:41 PM   #4
strat61caster
strat61caster's Avatar
http://www.newegg.com/Wireless-Route...5?Order=RATING
Old 08-21-2014, 11:26 PM   #5
litemup
Drives: around
Hey, they're still selling the wrt54gl? workhorse. Mine still works flawlessly after, geez, I don't even remember.
litemup is offline   Reply With Quote
The Following User Says Thank You to litemup For This Useful Post:
strat61caster (08-22-2014)
Old 08-21-2014, 11:48 PM   #6
menikmati
Drives: 2015 BRZ, 2005 STI
I'd also suggest the Linksys WRT54GL, haven't had any issues with mine for the past 3 years of ownership.
I believe that it's Tomato and DD-WRT compatible.
menikmati is online now   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
Old 08-22-2014, 01:04 AM   #7
litemup
Drives: around
Sure is, bought it for that reason.
Old 08-22-2014, 01:08 AM   #8
stugray
I still have a WRT54G as well.
The one I posted above is it's new big brother with beamforming (one step below phased array) technology.
And they designed it to be open source from the beginning because of the following that the WRT54GL had.
I am really surprised that it doesnt have a HDMI connector on the back.
It's a computer all by itself.
Old 08-22-2014, 01:16 AM   #9
litemup
Drives: around
Get Stu's suggestion. Reading up on it more carefully, yeah, I'm getting one too.
Old 08-22-2014, 01:24 AM   #10
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
http://www.smallnetbuilder.com/rankers/router/view
FWIW I built my own router using a dual-core Atom bookshelf PC and installed a BSD-based router OS called pfsense on it. Then I hooked up a Tenda W1800R (AC1750) router, on which I installed Tomato, to function as an access point. Just disabled DHCP, NAT, and other routing services to turn it into a WAP. It retails for $200 but I got it on sale from Newegg for $80 a few months ago.
My setup is very fast and stable, but the way I did it was a bit expensive off the bat. I wanted something small that had built-in Intel GBe NICs as they're better supported by BSD and didn't really have any older computer hardware lying around that fit my requirements.
I also wanted to make sure my ISP was the bottleneck, not my own equipment.
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 08-24-2014, 08:02 PM   #11
pushrod
Benched 86lb
pushrod's Avatar
Originally Posted by YMAA View Post
Thanks, I ended up buying #1 on this list.
The old me had a dedicated machine with PF+FreeBSD on it doing all kinds of fancy stuff.
Thanks for all of the responses, everyone.
Old 08-24-2014, 08:28 PM   #12
litemup
Drives: around
Wow, we were way off.
Gunman (08-25-2014)
Old 08-25-2014, 12:12 AM   #13
hypercarfanatic
Drives: Own F-150XLT, Lexus RX300
I wasn't the only one
hypercarfanatic is offline   Reply With Quote
The Following User Says Thank You to hypercarfanatic For This Useful Post:
Gunman (08-25-2014)
Asus Router icecreammmm Miscellaneous 1 08-25-2014 06:18 AM
Cradlepoint router with 4g Verizon Card install ML Electronics | Audio | NAV | Infotainment 2 10-27-2012 09:56 PM
cradlepoint 3g/4gLTE mobile broadband router Auto-Hauss Electronics | Audio | NAV | Infotainment 1 08-08-2012 05:55 PM
