Old 08-11-2014, 12:55 PM   #1
amilleri
Drives: 2010 Scion xD
Loud window pop
It only happens when the driverside door is closed and windows all the way up. When I push the roll window down button it makes a loud pop on its initial startup, if I open the door and do it it makes no sound, I feel as if the window regulator is off and causing it to pop from the pressure against the vehicle.
amilleri is offline   Reply With Quote
Old 08-11-2014, 03:06 PM   #2
humfrz
You might try wiping a bit of silicone on the rubber molding at the top of the window. Maybe it's sticking to the glass.
Or, the old fashioned way ..... put a bit of soap on the molding....
humfrz
Old 08-11-2014, 03:57 PM   #3
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Mine does it too. Happens when I roll down the window, or open the door. Will also happen when the window closes.
But, it doesn't do it every time. I've tried a little armor all type lube but it doesn't do anything.
celica73 is offline   Reply With Quote
Old 08-11-2014, 05:08 PM   #4
Shagaliscious
Drives: Firestorm FR-S (MT)
Mine does this very occasionally. I can't even remember the last time it happened, but i've had the car for 2 years and my window seals still look great, no leaking either. Seems like it's just an annoyance.
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 05:46 PM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 07:25 AM
Bad Hail Damage, loud window; About ready to give up on the FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 41 09-16-2013 07:25 PM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
