Old 08-10-2014, 11:14 PM   #1
evo8jpp
evo8jpp's Avatar
Drives: FR-S, WRX
5x100 Options
I have recently made the move into a FR-S but wondering whats options I have with the 5x100 pattern. I have two sets of Volk wheels in 5x114.3 in an Evo 8 fitment from my recent part out. I have been researching conversion adapters/spacers but wondering what are some opinions and experiences others have had. The obvious option would be to sell but one of the sets is a couple months old and mint. If spacers would work what would be a suggested size on a stock body FR-S? Any suggestions are appreciated. Thanks.
Set 1 - TE37SL in 18x9.5 + 22
Set 2 - RE30 in 18x9 +35
evo8jpp is offline   Reply With Quote
Old 08-10-2014, 11:37 PM   #2
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
The sticky threads will answer all your questions and then some. It only contains a ton of info, an amazing fitment calculator, and the most comprehensive wheel directory in the history of mankind.
Cheeseballs is offline   Reply With Quote
Old 08-11-2014, 12:46 AM   #3
Vten
Drives: Too heavy
Project kiks makes the 10mm adapters , but it'll make your first set to +12 and +25 to your second one .
The second one would fit easier without any needed excessive body works. But it also depends on how low you want to go suspension wise. The first set with +12 offset will need max negative camber on your top camber plate up front and you also need the camber bolts on the top slot of the struts. Pulled fender and rolled is necessary for sure .
The rear , you would need an LCA and adjustable toe link ... And if you want to go the "stance" camber , you'd need the UCA .
Just a heads up , most ppl here dislike the idea running an adapter and excessive camber. Me, I been using adapters all year along without any hick ups ... Knock on woods , camber set on -2F and -2.5R ...225/40/18 tires stretched on a 9.5 wide wheels +30 offsets on the summer set and 225/45/17 et 25 on the winter setup ..... At the end of the day , it's your car , do what you like with it
Anyway , hope that helps. Welcome to the forum and enjoy the stays ... Tons of info here that we can learn together .
Vten is offline   Reply With Quote
Old 08-11-2014, 04:52 PM   #4
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I would say those are both going to be too aggressive with adapters unless you really want aggressive wheels and have something suspension/stance/bodywise in mind.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 08-11-2014, 04:57 PM   #5
jdmblood
jdmblood's Avatar
Drives: white subaru brz
i doubt the te37s would be very easy to fit with the 10mm spacers as stated above. your better off trying out the re30 since they are also 9's compared 9.5's and you can see how they fit depending on what tire size you want to run and whether or not you want to do fender work. it is also important to state whether you are going for a stretched tire look like (stance wise) or a meaty tire. and yes the 10mm converters are your best bet
jdmblood is offline   Reply With Quote
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
17x8.5 +45 5x100, any options? #87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-13-2012 03:10 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
