Old 08-10-2014, 08:52 PM   #1
Hawk77FT
Drives: GTS 86
Throttle body spacers
I am contemplating these as it is another way to push more air volume into the intake manifold.
Is anyone using them? Where did you get them from? And do you feel any difference?
Hawk77FT is offline   Reply With Quote
Old 08-10-2014, 08:55 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I haven't tested anything, but people here that have their cars built, even the forced induction turbo and s/c guys don't need a bigger TB. it's already oversized for stock anyway.
Old 08-10-2014, 08:59 PM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
He's talking spacers, not larger throttle bodies.
Back to the topic. I'm curious if they're worth it, but unless the cost was low I'd still wait for a after market intake manifold
Freeman is offline   Reply With Quote
Old 08-10-2014, 11:16 PM   #4
Hawk77FT
Drives: GTS 86
So you havent tested anything, yet you make a statement on something that you dont hold knowledge of.
Ok, I was talking about spacers on the throttle body.
To answer your question, I have an increased size tb to 68 and it makes a difference. Not huge but noticeable, so I guess the engine could benefit from more air volume in the intake.
Back on topic!
Old 08-10-2014, 11:23 PM   #5
s2d4
s2d4's Avatar
How does it push more air volume into the intake manifold?
Old 08-10-2014, 11:44 PM   #6
subaruindo
Drives: subaru brz satin white
big throtle + spacer make more torque. i'm use 70mm + spacer
subaruindo is offline   Reply With Quote
Old 08-11-2014, 12:00 AM   #7
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Fact or placebo? Have you got dyno charts to show the improvements?
Fizz is offline   Reply With Quote
Old 08-11-2014, 12:20 AM   #8
steve99
Theoreticly a throttle body spacer should have the same effect as the crawford BPB. ie changes the volumetric efficency of the engine to produce more power/torque in a particular rpm range. Can you get enough volume in a throttle body spacer as compared to BPB wotld be the question and also is that volume increase beter closer to the individual intake ports as oposed to the collective volume increase behind the throttlebody.
The BPB seem to do their best on stock cars with stock tune, they produce some power increase and shift the peak power lower in the rpm range.
Once you start tunig the car and doing other things to increase the volumetric effiency such as cam timing changes and catless headers with different length and diameter primary tubes the increase you get from BPB is diminshed.
Yes you would have to dyno before and after to be sure of anything.
Old 08-11-2014, 12:35 AM   #9
stugray
Drives: 2013 GBS BRZ Limited
Theoreticly a throttle body spacer should have the same effect as the crawford BPB. ie changes the volumetric efficency of the engine to produce more power/torque in a particular rpm range. ...
I think the point of the BPB is that the RUN directly into the intake valve runner is longer allowing the intake charge to maintain more momentum into the valve.
My guess is that adding more "Run" before the diverter portion of the intake manifold will make little to no difference.
Or just adding an intercooler with no FI would do that too no?
Old 08-11-2014, 12:41 AM   #10
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Which throttle body are you using?
Carlitoz3 is offline   Reply With Quote
Old 08-11-2014, 12:55 AM   #11
Hawk77FT
Drives: GTS 86
What spacer do you use?
Old 08-11-2014, 12:59 AM   #12
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
LoL that's something I can't wait to see! Please tell me nobody already does this for other platforms?
Old 08-11-2014, 01:14 AM   #13
Fast_Freddy
Drives: Passat
Would love to see the dyno sheets supporting claims that larger then necessary throttle bodies add hp/tq.
IIRC, when Shiv tested the Crawford manifold spacers all they did was shift the hp/tq peak with no peak gains. After many hours of tuning he managed to regain some of the higher rpm hp/tq lost with the spacers, making for a slightly wider powerband.
Fast_Freddy is offline   Reply With Quote
Old 08-11-2014, 05:33 AM   #14
zooki
Drives: waiting on a 2021...
I would have to agree with this. The only way I could see it affecting anything is adding to the plenum volume, maybe, theoretically helping out in the upper RPM's. But I would think the small amount the spacer would add would not be noticeable in the real world. Except to those people who swear they can feel that 3 Hp@7000 RPM that a drop in filter gives them.....
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
WTB: OEM fa20 Throttle Body 1stGenBRZ86 Want-To-Buy Requests 0 01-28-2014 02:51 AM
WTB: Factory FR-S / BRZ Throttle Body Chase Bays Engine, Exhaust, Bolt-Ons 0 07-15-2013 07:16 PM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
