Old 08-08-2014, 11:39 PM   #1
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
$6 cosmetic battery tie-down fasteners.
I swapped-out the huge OE Panasonic battery last year for a sealed Optima battery. The Optima was a little shorter and I've been driving around with 2" of exposed all-thread. So today I finally remembered to cut down those little all-thread tie-downs. Hit the hardware store after work and bought a pair of black nylon wing-nuts with 6mm threaded brass inserts and a pair of 1/8" thick white nylon washers. I think it looks pretty clean. Total cost was $6.00
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
humfrz (08-09-2014)
Old 08-10-2014, 12:34 AM   #2
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
This is completely off-topic, but is it safe if I don't have the red positive cover on my battery?
904FRSlow is offline   Reply With Quote
Old 08-10-2014, 03:32 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That cover is cheap insurance. It is there for the remote chance of you dropping a conductor (spanner,screwdriver, not the person who leads an orchestra) on the positive terminal and earth while the negative terminal is still connected to the earth lead. If that happens..... no, you are not going to let that happen.
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 08:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
DIY cosmetic modification. zooki Cosmetic Modification (Interior/Exterior/Lighting) 0 08-16-2012 03:24 PM
Cosmetic Key Modification ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 13 07-01-2012 06:30 PM
