Old 08-08-2014, 07:32 PM   #1
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Question Can someone explain tire-stretching?
It would be appreciated, as I have zero understanding of this phenomena.
Thrustin is offline   Reply With Quote
Old 08-08-2014, 07:36 PM   #2
themajesticone
themajesticone's Avatar
Drives: '13 UM86
http://forums.vwvortex.com/showthrea...-afraid-to-ask
[ame="https://www.youtube.com/watch?v=LADnwQ3g9KY"]How to stretch a tire... and how you don't. - YouTube[/ame]
themajesticone is offline   Reply With Quote
Old 08-08-2014, 07:36 PM   #3
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
Point blank. It's where the tire is stretching.
If you have a 17x9 wheels and have a tire that's say, 215/40/17, it's going to stretch because it doesn't fit correctly. There's a lot of air inside those tires, so it's trying to fit and fill the rim, but it's too small.
ihaskrayon is offline   Reply With Quote
Old 08-08-2014, 07:39 PM   #4
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
you do it for the sloots
calmtigers is offline   Reply With Quote
Old 08-08-2014, 07:46 PM   #5
Thrustin
Maybe I should've been more specific in my line of questioning.
Let's try again.
Why?
This is the type of info I'm after.
Old 08-08-2014, 07:51 PM   #6
themajesticone
Drives: '13 UM86
Let's try again.
Why?
Not sure how accurate this is but reading the link I provided you says,
the whole thing started in germany/belgium, local laws required that the tire tread be within the fender line.
well that doesnt allow one to run wider or lower offset wheels, so they put narrower tires on the wheel to maintain legality
when you would like to run really wide or low offset wheels and keep the tire tread at the fender
when you would like to go really low and not rub
Old 08-08-2014, 08:10 PM   #7
calmtigers
On the real I've heard multiple reasons
1. looks
2. run wider rims (fitment issues)
3. I've heard slide better (drift?)
4. Some stock cars run a tiny bit of stretch (bmws)
BTW all this,
for the sloots
Old 08-08-2014, 08:10 PM   #8
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Its when you like to do something not recommended by the manufacturer and put everyone else around you in danger to look "cool."
Hellaflush yo!
Subaru STI :
Old 08-08-2014, 08:19 PM   #9
2much
I wanna go fast
Drives: 2013 FR-S 6MT
stretch = form
proper fit = function
2much is offline   Reply With Quote
Old 08-08-2014, 08:52 PM   #10
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
It's a symptom of being dropped on your head as a baby.
sittinSideways is offline   Reply With Quote
Old 08-08-2014, 09:24 PM   #11
calmtigers
Hellaflush yo!
depends on the stretch, I'm sure people realize that the manufacturer also doesn't recommend making any changes (yes those chunkier/"safer"/stickier tires aren't recommended )
Old 08-08-2014, 09:35 PM   #12
wparsons
wparsons's Avatar
People do it so they can run wider rims and lower offset, mostly just so they can say they have 12" +20 wheels, regardless of how poorly they fit. With a stretched tire it won't rub on the body as much.
Kinda like this:
flickr
Old 08-08-2014, 11:52 PM   #13
sirsol66
Drives: 2013 FRS- Hot Lava
Originally Posted by 2much View Post
stretch = form
Not necessarily true, from a tire engineers point of view. A slightly stretched tire is actually better (when considering a street tire, race tires are a whole different ball game) at quickly building cornering power since you do not have to deal with sidewall deflection (or at least reduced) during initial turn in. As a rule of thumb I always run my tires one size up recommended wheel width from JATMA, ETRTO, or T&RA. This of course only applies within reason, the aftermarket tire stretching you see is absolutely crazy in my opinion.
sirsol66 is offline   Reply With Quote
Old 08-09-2014, 03:02 AM   #14
2much
I wanna go fast
I wouldnt dispute any of that. apply the statement to street cars only, does that change?
new to OFT, can someone explain? l0aded Software Tuning 7 03-22-2014 11:25 PM
I'll try to explain whaap Off-Topic Lounge [WARNING: NO POLITICS] 19 01-24-2014 09:35 AM
For those who ask about stretching tires Vic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-08-2014 12:02 AM
PLease explain to me why im the *sshole bdanisi Scion FR-S / Toyota 86 GT86 General Forum 82 02-07-2013 02:37 PM
Stretching will lead to a firey death frosty86 Off-Topic Lounge [WARNING: NO POLITICS] 6 10-19-2012 03:31 AM
