Old 08-07-2014, 11:48 AM   #1
The86Ghost
Drives: 2014 FRS (Whiteout)
Coilover Practicality?
Hey there guys i have been wanting to buy a set of coilovers for a little while now but am just not sure due to a few questions. I have been looking at d2 rsr or bc racing. I just want to know will i be bottoming out all day? How does this effect driving in snow? I don't care much about how firm the ride is, that wont bother me but if i get a apr splitter I don't want to fuck it up going into my driveway. This is my DD by the way so consider that i also am thinking about lowering springs since those don't drop quiet as much as coilovers
Just let me know your experience with coilovers/lowering springs
thanks for reading
The86Ghost is offline   Reply With Quote
Old 08-07-2014, 12:02 PM   #2
FR-S Matt
Let me make this easy for you. You get what you pay for when it comes to suspension. I started with $1000 coilovers and am now using $2000 ones and the difference is light and day. The ability to adjust rebound and compression makes a massive difference even if you just street drive. It also gives you the ability to change it if you ever drive on the track.
I daily drive on KW V3's and I absolutely love them.
Old 08-07-2014, 12:26 PM   #3
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
The thing about coilovers is that if you start out too low, you can spend an afternoon taking them off the car and raising them up so that you don't bottom out as much.
Also, like FR-S Matt said, don't cheap out.
Jyn is offline   Reply With Quote
Old 08-07-2014, 01:47 PM   #4
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
you will most likely have the car oversprung on the cheap coilovers so bottoming out wont happen unless you slam it to the ground. you need to learn to drive a low car, and your splitter will be fine.
could you AT LEAST consider some RCE tarmac zero's or bilstein PSS...i mean why dont you just go buy racelands if you're already cheapening out.
Jive Turkey is offline   Reply With Quote
Old 08-07-2014, 01:52 PM   #5
Jacky
Jacky's Avatar
Drives: 2011 Mitsubishi Evo X
Mine is low but moderate. I love it.
WAS your Vivid Racing Rep for FT86club but now just a Parts Ninja@Vivid Racing
Jacky is offline   Reply With Quote
Old 08-07-2014, 01:54 PM   #6
The86Ghost
What coilovers are you using?
Old 08-07-2014, 01:59 PM   #7
Jacky
Jacky's Avatar
I use the Stance SS coilovers. Well Priced.
Old 08-07-2014, 02:15 PM   #8
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
This guy gets it. Best advice based on this.... Don't cheap out. All too often people are like .."it's only for daily driver I don't race". That don't matter and you say now you don't care if it's abit firm but trust folks you will care and your back and ass will care. There's a lot of junk out there so save and do it right day one IMO.
Old 08-07-2014, 02:44 PM   #9
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
I daily drive mine, just hit 42,000 miles and have had coilovers since about 15,000 miles. I originally had RCE Yellow springs and they were nice, but I should have done coilovers first and saved some money. I went with the RCE Tarmac 0's and I love them.
I scrape occasionally but it is usually when I screw up and take a driveway exit too fast or go somewhere I know I shouldn't drive. Unless you are going super low then daily driving a decent coilover at a ride height off the ground will be no problem.
I do not drive in snow here so I can't help you there. Echoing what everyone else said, don't go super cheap on coilovers.
UnOvertime is offline   Reply With Quote
Old 08-07-2014, 02:58 PM   #10
CBR600RR
Drives: Raven Black
I've said it many times before in other threads< ST suspension coilovers are the best INO if you just want a street coilover. They aren't expensive (Sub $1000). They aren't much stiffer than stock, they reduce body roll, and lower from -0.8 inches to -2.0 inches)
They will handle the odd AutoX or TD too.
Old 08-07-2014, 03:11 PM   #11
FR-S Matt
I'd be willing to bet those have the same issues once you start going around the 1.5" drop range that my Tarmac 0's had.
Old 08-07-2014, 03:13 PM   #12
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Or...just buy some Koni struts and RCE/RS*R/Swift springs or Bilstein shocks, get a mild coilover like drop without the worry of ever needing to aide or lower it and call it a day.
Old 08-08-2014, 02:01 PM   #13
CBR600RR
Drives: Raven Black
what issues? I am at a 1.5 drop right now. I can make it up all driveway curbs and over all speed bumps without incidence if I am cautious.
I have no issues with mine what so ever.
The ST coilovers are very basic though. No adjustability except height. ST focuses on quality and simplicity in their coilovers.
Old 08-08-2014, 02:21 PM   #14
FR-S Matt
Not actual drop issues and clearance. More the issue of the travel on the coil going over road imperfections, small bump hills, and seeming very "bouncy". That all went away on my V3's regardless of drop.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
FS: KW Coilover Kit V3 FR-S / BRZ FT-86 SpeedFactory Brakes, Suspension, Chassis 10 09-12-2014 12:23 AM
Yet another 'Which Coilover Should I Get ?' mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 04-23-2014 09:20 AM
Safety & Practicality? Re~Mix Scion FR-S / Toyota 86 GT86 General Forum 9 07-02-2013 03:10 PM
FS: (QC) STD R9 Coilover dompower Brakes, Suspension, Chassis 4 05-04-2013 04:08 PM
