Old 08-03-2014, 01:36 PM   #1
WinnaWinna17
Drives: 2013 Scion FRS, 1998 Sentra SE
Sounds from the engine
Does anyone else hear the engine purring like sound when it remains in park? I have an automatic 2013 FRS and got it used and still has less than 9000 miles. I do not know if the former owner screwed up the engine internally or something. The sound is kinda like a hoofing sound, coming from inside the engine. Not a belt, but maybe a fan. I have not personally met someone else to compare the sound to. You can also hear it when you are at a stoplight with the windows down.
Cheerz!
WinnaWinna17 is offline   Reply With Quote
Old 08-03-2014, 01:46 PM   #2
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
We need a video/sound clip otherwise this thread is useless sorry bud
Old 08-03-2014, 01:55 PM   #3
Tromatic
Is your AC on when this happens?
Tromatic is offline   Reply With Quote
Old 08-03-2014, 02:04 PM   #4
WinnaWinna17
Yes AC is on, 100 degrees in Los Angeles too.
Old 08-03-2014, 03:19 PM   #5
humfrz
Cheerz!
WELCOME to the site, WinnaWinna17 ......
Could you expand on ..... "hoofing sound" ... ??
Does it make the sound with the A/C OFF .. ??
Are the cooling fans running when it's making the sound.. ??
If so, you may check and make sure a piece of trash is not coming in contact with the fan blades.
Did it just start doing this .... ?? If so, have you done any engine related mods since it started .. ??
Come back with more info; maybe we can help .....
humfrz
Old 08-03-2014, 03:34 PM   #6
Havsie
Havsie's Avatar
Drives: 13 FR-S Whiteout 6MT
Sounding like a tractor at idle is normal for a flat engine.
Havsie is offline   Reply With Quote
Old 08-03-2014, 04:42 PM   #7
poison1916
Drives: Scion FR-S Hot Lava
does the sound subside once the oil temp reaches average?
poison1916 is offline   Reply With Quote
Old 08-03-2014, 06:10 PM   #8
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
Do you hear a singing sound though?
Cliu91 is offline   Reply With Quote
Old 08-03-2014, 07:36 PM   #9
Tromatic
So it's not the AC compressor starting and stopping? Need a better description of, "purring" and "hoofing" are new ones on me.
Old 08-03-2014, 07:38 PM   #10
Tromatic
Running the OFT E85 tune, mine is remarkably smooth and quiet at idle.
Old 08-03-2014, 10:14 PM   #11
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Can you mimic the sound and record it using your voice?
Old 08-04-2014, 10:11 AM   #12
WinnaWinna17
I will post a video with audio when I get the chance to, thankz.
Old 08-04-2014, 11:38 AM   #13
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Mine has a lot of what I've been referring to as "a lot of belt noise" and depending on the day I'm either concerned or convenience it's just another noise this car makes.
Nevermore is offline   Reply With Quote
Old 08-04-2014, 12:11 PM   #14
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
no one has mentioned crickets?
There must be something wrong with the forum...
OP, pretty sure your car is just fine.
automatic transmission, engine, noise
Sounds better set to TC Jigglybus Electronics | Audio | NAV | Infotainment 3 07-19-2014 01:44 PM
Normal engine sounds BrianBlueBRZ Engine, Exhaust, Transmission 3 06-28-2014 12:49 AM
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 02:24 PM
it sounds good! pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 08-09-2012 04:46 PM
Video: TRD 86 Exhaust and Engine Rev Sounds tmigo27 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 02-11-2012 06:36 PM
