Old 08-03-2014, 01:18 AM   #1
Stodium
Drives: 2014 Scion FR-S
Car Keys Not Working *2014 Monogram Series*
Hey everyone
so i got my car about 3 months ago so its relatively new. Anyways I went on a vacation trip and had my car car parked outside under a car cover for 4 days, i come back and the i try using the keys but they're not working. They're keyless keys so I can't manually open the car.
Do you know whats wrong? I'm in absolute panic mode as I have work tomorrow and this is my only ride. I dont think its the battery cos the keys light up everytime I press the button. But nothing works. Locking, unlocking, trunk, panic button... nothing! any help would mean a lot.
Stodium is offline   Reply With Quote
Old 08-03-2014, 01:21 AM   #2
qwerty66
Drives: frs
Replace the remote battery
qwerty66 is offline   Reply With Quote
Old 08-03-2014, 01:54 AM   #3
cnk
Drives: '13 DGM BRZ Limited
You should still have a keyhole in the driver's side door. Your keyless remote has a button on the side. Push it in and you can remove the key from the key fob and use it to unlock your car.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
Stodium (08-03-2014)
Old 08-03-2014, 02:32 AM   #4
Kaotic Lazagna
Drives: GR Corolla
Side of the key has a button. Push it, and a key slides out from beneath. Unlock the door, hold the key fob directly in front of the PTS button, covering half of it. Then push to start the engine (either brake or clutch depressed, depending on M/T or A/T).
Old 08-03-2014, 02:33 AM   #5
Kaotic Lazagna
Drives: GR Corolla
Hopefully that works (also try your second key fob normally). If it does, go to your service center ASAP and open a repair order with the service adviser.
Old 08-03-2014, 04:23 AM   #6
steve99
Yes that will work for flat batt in key fob, but other likely scenario is car battery is flat due interior light left on or similar.
Time for the jumper leads (or whatever you guys call them). You can "clutch" start the manual with push button start if their is sufficient power for ECU.
Press start button twice WITHOUT depressing clutch car now "on" roll/push car now depress clutch select second gear release clutch (do not touch start button) , all good should start.
Will not work if battery is totally dead but will work if its just not good enough to turn starter motor.
Old 08-03-2014, 08:15 AM   #7
White64Goat
Originally Posted by Stodium View Post
Hey everyone
So, you didn't read the owners manual yet huh?
I assume you got in the car with the key?.................
Old 08-03-2014, 11:13 AM   #8
extrashaky
Drives: 2014 BRZ Limited
I'm betting the owner's manual was INSIDE THE LOCKED CAR.
The Following User Says Thank You to extrashaky For This Useful Post:
Annahra (08-03-2014)
Old 08-03-2014, 12:03 PM   #9
Luis_GT
You don't even need the manual to realise the key fob has a damn key...
The Following User Says Thank You to Luis_GT For This Useful Post:
Sportsguy83 (08-04-2014)
Old 08-03-2014, 02:49 PM   #10
Stodium
lol yup. I dont read manuals, sorry. just dont have the time for it and would rather not keep my house a mess and end up losing it..
ANYWAYS, for all the people that are nice enough to give advice. the key isnt even working to open up the car manually, so I'm pretty much stuck at this point. Going to try to replace the battery and hope for the best.
Old 08-03-2014, 03:40 PM   #11
White64Goat
Are your friends 'Punking' you and maybe it's not your car?
The Following User Says Thank You to White64Goat For This Useful Post:
Old 08-03-2014, 03:41 PM   #12
White64Goat
Owned for 3 months.........
Old 08-03-2014, 04:05 PM   #13
extrashaky
If the door key won't work, how are you planning to get the hood open from outside the locked car?
It'll work. Everybody who has this happen has trouble with the lock. You just have to turn it harder. It will give way and open.
Old 08-03-2014, 04:31 PM   #14
Stodium
i found my spare key which managed to work (strange). got my hood open, and you were right about the battery being dead. but what gives? I checked to see if any of the lights were on and everything was already set to off, should I be concerned about my car dying out from a 4-day vacation?
<>GEAR WAGON<> 2014 FR-S Monogram Series Cockatoo Member's Car Journals 43 09-03-2019 11:57 AM
2014 Scion FR-S Monogram Series Cycotech Scion FR-S / Toyota 86 GT86 General Forum 23 03-30-2014 09:24 PM
2014 Hot Lava Monogram Series ;) Haeb FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 03-24-2014 02:28 PM
Scion tC and FR-S 2014 Monogram Series to be available in early 2014. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 655 01-10-2014 05:03 PM
2014 Fr-s or wait until monogram series.. NamedRyan Scion FR-S / Toyota 86 GT86 General Forum 27 10-28-2013 10:11 AM
