Old 07-28-2014, 03:28 PM   #1
Fastbrew
Drives: 2014 Pearl White BRZ
Electronic blind spot indicator - mirrors
So - I have rented a car while my BRZ is being tuned.
Hertz had a Buick Verano available so I grabbed it.
Not my cup of tea in an auto, however - I LOVE the mirror indicator for the blind spot.
On the outside of the mirror glass, there is a little orange indicator that lights up when someone is in your blindspot(s). It worked perfectly.
Has anyone tried adding this to their twin?
I know about convex mirrors - I am interested in this setup. I know there is no substitute for looking - however - even after looking around this extra little check is pretty awesome.
Fastbrew is offline   Reply With Quote
Old 07-28-2014, 03:42 PM   #2
STV3
Seρor Member
STV3's Avatar
Yeah going to be more money and work then its worth. Just get a set of rexspeed mirrors and call it day.
STV3 is offline   Reply With Quote
Old 07-28-2014, 03:44 PM   #3
uEih
Drives: CBS Subaru BRZ Limited
Do those need sensors somewhere installed? Not sure how those works and I've never been in a car with one but I find it the BRZ doesn't have blindspots in the mirrors, once a car is out of the sight of my mirror I could already see them on the side. I still check blindspots anyways in case a car on the other lane is trying to change into the same lane I'm changing into, those annoy me as I've had a close call when someone decided to change lanes quickly without signaling when I was already halfway through the lane change.
uEih is offline   Reply With Quote
Old 07-28-2014, 03:45 PM   #4
sklimo
Originally Posted by Marchy View Post
yeah i don't trust those. I can see in most cars/trucks equipped with those sensors that they don't register the twin until were almost side by side. I've had to avoid nearly being side swiped 2 times already in the 3 months from vehicles with said blind spot indicators.
Marchy (07-28-2014)
Old 07-28-2014, 03:52 PM   #5
gramicci101
Off Topic
Adjust your mirrors properly and you won't need them.
From your driving position you shouldn't be able to see the sides of the car.
Lean your head left until it touches the window. Turn the left mirror out until you can barely see the side of the car.
Lean your head right until it's at about the middle of the vehicle. Turn the right mirror out until you can just barely see the side of the car.
Make minor adjustments as necessary.
Now when a vehicle leaves the edge of your rearview mirror, you're picking it up in your side mirror. And when it leaves the side mirror, you can see it with a cursory head check. If there's a car on your back corner, it will be squarely in your side mirror.
The Following 8 Users Say Thank You to gramicci101 For This Useful Post:
chaoskaze (07-28-2014), Ganthrithor (07-29-2014), go2brz (07-30-2014), Marchy (07-28-2014), Poodles (07-28-2014), sklimo (07-28-2014), Sp8ceCadet (07-28-2014), tahdizzle (07-28-2014)
Old 07-28-2014, 04:00 PM   #6
sklimo
seriously, it wouldn't have been a blind spot IF YOU PROPERLY ADJUSTED YOUR MIRRORS, USED THEM AND NOT BLINDLY TRUST A STUPID GIZMO IN YOUR CAR.
but fuck me, right in the arse.
i'm waiting for the news story where someone says "but my blind spot indicator didn't tell me that car/motorcycle was there, lets sue "insert car manufacturer here".
The Following 4 Users Say Thank You to sklimo For This Useful Post:
Ganthrithor (07-29-2014), gramicci101 (07-28-2014), Poodles (07-28-2014), tahdizzle (07-28-2014)
Old 07-28-2014, 10:46 PM   #7
Poodles
Drives: 2015 Series.Blue
You guys beat me to the whole adjusting your mirrors correctly
Sadly, it seems it's not the norm, and because of this some cars from the factory won't adjust out that far.
Old 07-28-2014, 11:00 PM   #8
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Trade your car for a Buick OP.
Old 07-29-2014, 12:50 AM   #9
Fastbrew
Hell no! The only reason I picked it up was because my BRZ is getting an AVO and a tune right now and I wanted something really lame so that the experience of getting back in the BRZ later this week is amplified.
PS - I found some Toyota parts to accomplish this task so I might mess with this later.
Old 07-29-2014, 01:13 AM   #10
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
This.
An easy way to set your mirrors up is to have a friend walk from side to side behind your car. You want the mirrors set up so that as the person is leaving one mirror they're entering another.
Ganthrithor is offline   Reply With Quote
Old 07-29-2014, 01:21 AM   #11
Fastbrew
I have already configured my mirrors in that fashion.
I started this thread to talk about electronic blind spot indicators and the tech behind it. If I wanted to talk to people about mirror adjustments, I would have made a thread called "How do I adjust my mirrors" - alas - the title is "Electronic Blind Spot Indicators - mirrors" So, my bad for putting mirrors in the title and confusing people. I meant it as the location for the indicator.
Old 07-29-2014, 02:08 AM   #12
Fastbrew
This looks like a possibility. Gosher's - http://www.goshers.com/blind-spot-de...ds3016-10.html
Here is some installer showing it off
[ame="https://www.youtube.com/watch?v=6joY5uMIA9k"]Goshers Blind Spot Detection System 2012 Toyota Prius - YouTube[/ame]
My problem is that I would have a hard time looking at those little circles cut into the vehicle. Even if it was paint matched.
I guess you can get away with just the rear sensors. They sell it in that config.
I would be more apt to opt for a side skirt solution if I wanted to do this.
Old 07-29-2014, 02:37 AM   #13
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Even adjusting the stock mirror properly and using a blind spot indicator are no match for these:
The one single thing I miss from driving German cars, I can change lanes on the driver side so fucking fast with no need to shoulder check.
Blind spot indicator? Cuz Volvo!
krayzie is offline   Reply With Quote
Old 07-29-2014, 02:45 AM   #14
Fastbrew
What's that off of? That slays for visibility. I do not like the stock mirrors and Rexspeed seems to be the goto - however - that mirror makes it look silly.
Corrected the blind spot... Mikem53 Scion FR-S / Toyota 86 GT86 General Forum 76 06-24-2014 05:33 PM
Blind Spot Detection? Reggaeboyz Electronics | Audio | NAV | Infotainment 25 02-03-2014 03:33 PM
Blind spot? euroshowoff Scion FR-S / Toyota 86 GT86 General Forum 47 12-28-2013 04:38 PM
Blind spot check on BRZ. qqzj BRZ First-Gen (2012+) — General Topics 44 11-21-2013 02:44 AM
Blind spot mirrors? enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-11-2012 02:29 AM
