Old 07-27-2014, 12:03 AM   #1
2k14frs
Drives: 2014 black frs.
Uel header vs El header
Was doing some research, and somebody said on another forum that a uel header was causing his ecu to malfunction because of different pressure from the pistons. I don't know much about cars, but more than willing to learn. Anybody know if this will be a problem if I purchase a uel header? Or what's better to run, El header or uel header?
2k14frs is offline   Reply With Quote
Old 07-27-2014, 12:07 AM   #2
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
Dependent on the header design you will more than likely throw a CEL code which is why most companies recommend you tune your car after install. EL usually provides more power than a UEL but you lose the boxer rumble. I ran my Nameless EL headers vs a friend with Borla UEL headers. I pulled him in 2nd and 3rd, he pulled me in 4th. The gains wont be too significantly apart from each other so its basically going to come down to preference. Hope that helps.
2024 Toyota GR86
2013 Scion FR-S
briang0901 is offline   Reply With Quote
Old 07-27-2014, 04:22 AM   #3
akahenry
akahenry's Avatar
Drives: '18 STi
Please use the search button.
akahenry is offline   Reply With Quote
Old 07-27-2014, 05:49 AM   #4
steve99
If they are both well designed headers their will be little difference in performance.
EL generally produce slightly more top end power
UEL generally produce slightly better midrange
only a few hp in it
Just pick the sound you like UEL for clasic subbie rumble .
Stock header has catylitic converter, if you put on catless headers either uel or el it will likey throw a cel code due missing cat. Catted headers either type should not throw cel code . You can get a O2 sensor spacer to hopefully stop the cel code.
To get max benifit from either type of header you need a tune, you might only get 5 hp gain without a tune but 15 hp with tune and better midrange and no cel code as tune will disable the cat efficiency cel code
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
