Old 07-21-2014, 01:47 PM   #1
Bruh Man
Drives: 2011 corolla (will purchase brz)
so my corolla 2011 is automatic
I Only did this a few times, but I need to know if it would destroy my transmission.
While I'm driving and the shifter is in d . at maybe 2k or 3k reps I shift it down to 2 to get higher revs and faster acceleration Is it bad on the car.
I need a nonopinionated answer Thanks.
Bruh Man is offline   Reply With Quote
Old 07-21-2014, 02:00 PM   #2
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
I think you are going to wear out your torque converter and it is expensive to fix. your little corolla is not really design to drive that way, please don't drive that hard.
Speed2th is offline   Reply With Quote
Old 07-21-2014, 02:17 PM   #3
radroach
Drives: car
My thoughts are no, though it's probably intended for towing / engine braking, not for more acceleration.
Old 07-21-2014, 02:44 PM   #4
HapaHaole
Drives: Grocery cart
The torque converter is not going to wear, given he isn't using the torque converter lock at that low of a speed.
Your going to damage the clutches / bands inside the transmission if you do that frequently.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 07-21-2014, 03:00 PM   #5
Speed2th
Speed2th's Avatar
Drives: 2010 335d
sure i could be wrong, not really knowing automatic transmission well
Old 07-21-2014, 03:38 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
whats wrong with just putting your foot to the floor?
The Following User Says Thank You to ZionsWrath For This Useful Post:
tahdizzle (07-21-2014)
Old 07-21-2014, 03:44 PM   #7
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Might not feel slower, but dropping gear like that probably is :P
The Following User Says Thank You to tahdizzle For This Useful Post:
ZionsWrath (07-21-2014)
Old 07-21-2014, 04:44 PM   #8
Chauntalei
Drives: Non-BRZ
This. If you just hit the pedal with some oomph, the transmission is programmed to downshift to give you more power, and then it'll shift back up once it hits the 'appropriate' speed.
2013 SSM BRZ Limited 6MT - 5/28/2012-10/28/2014
Chauntalei is offline   Reply With Quote
Old 07-21-2014, 10:29 PM   #9
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
There is something called "kickdown", it is activated when you step on the accelerator pedal all the way to the very bottom (some cars have a notchy feel at the very bottom of the stroke to tell you that's to activate it). Kickdown enables the auto tranny to goto the lowest possible gear for maximum acceleration.
When driving the car, always keep the shifter in "D". Some cars have multiple D selections to allow you to select a lower gear for normal driving (i.e. D3, D4 like on the old Hondas). I remember old Toyotas have an O/D (overdrive) button which does the same thing. Gear selector "2" is for engine braking when going downhill, while "1" (if yours have it) is for towing.
I don't think your Corolla slushbox knows how to blip the throttle on downshifts, so yes it's bad for the tranny with what you are doing.
If you read the user's manual, this should be all clearly explained to you (but I just saved you 5 mins of flipping thru it).
krayzie is offline   Reply With Quote
Old 07-23-2014, 10:51 AM   #10
Bruh Man
Thanks guys really appreciate it. I haven't done it too often so I won't anymore. I'm going to put some wheels on it 18" and then use those on the brz when I get it. 5 by 100
Old 07-24-2014, 08:43 AM   #11
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
I've done that in my automatic car before (Toyota Landcruiser Prado) felt like it was engine braking and slowing down rather than just trying for higher revs for acceleration.
Just my personal experience
wtrxprs007 is offline   Reply With Quote
Old 07-24-2014, 09:22 AM   #12
stugray
Drives: 2013 GBS BRZ Limited
This is no different than the trans performing its own "kickdown" as mentioned above.
Now granted modern trans usually have a computer in it somewhere that is capable of making some decisions so letting the trans perform it's own kickdown is probably safer than forcing it.
The Following User Says Thank You to stugray For This Useful Post:
Poodles (07-27-2014)
Old 07-27-2014, 05:55 AM   #13
Poodles
Drives: 2015 Series.Blue
This. You're not doing anything bad to the transmission at all.
Old 07-27-2014, 07:05 AM   #14
Grim-Reaper
Grim-Reaper's Avatar
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
To come back to old Toyota ATs:
My 91 Supra is AT with 3 "gears" and overdrive as 4th.
Any problems leaving OD on all the time? Manual suggests turning OD off only if you notice it shifting up, down, up, down... Like on uphill.
Grim-Reaper is offline   Reply With Quote
FRS Wheels on Corolla Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 02-19-2017 05:02 PM
2014 corolla looks like BRZ lionbacker54 Other Vehicles & General Automotive Discussions 39 04-07-2014 12:46 AM
Thoughts on new Corolla? Kimsey47 Other Vehicles & General Automotive Discussions 46 06-13-2013 08:49 AM
How is a Corolla beating all the FRS's? lsxiong Scion FR-S / Toyota 86 GT86 General Forum 40 04-18-2013 01:25 PM
Corolla GT-S Rampage Other Vehicles & General Automotive Discussions 6 07-08-2012 09:10 AM
