Old 07-21-2014, 03:33 AM   #1
vynervt
Drives: GT-86
Question Gtech- Pro SS performance meter - on road dyno
Dear All,
Anyone had experience using this device? I brought OFT and Gtech Pro SS together and I'm not so sure whether I set the setting correctly. I had do a few runs on original engine but seen to me i get the calculate setting wrong.
Can anyone assist me on the information i needed to set in G-tech pro SS?
The information need to set in Gtech - pro:
original vehicle weight MT is 1275 kg
Frontal Area = how to convert it to m2? 1775mm x 1320mm=??2.343m2?
drag coefficient =0.27
Drive train loss = how many %, max 20.
During on road dyno pull should i include my body weight for more accuracy?
Thanks!
vynervt is offline   Reply With Quote
Old 07-24-2014, 09:08 AM   #2
bfrank1972
Drives: 2013 FR-S Argento
Yes you need to use actual weight of the car with you in it. I'm not sure about the model you have, but the gtech I used to have was a bit optimistic. On my old E36 m3 it would read abut .3-.4 secs optimistic, but it's a decent tool for estimating effects of mods etc.
bfrank1972 is offline   Reply With Quote
Old 07-25-2014, 09:19 AM   #3
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
There's an iPhone app that is actually made by the same guys...every time I add a mod, it says I make less power
Stock I was 139hp
After the Crawford BPB and OFT tune it dropped to 125
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 07-25-2014, 10:30 AM   #4
wparsons
wparsons's Avatar
Why bother with this when you can just run 3rd (or 4th) gear logs through VirtualDyno and get good estimates? If the road is perfectly flat and low wind, the results are VERY close to a real dyno.
There's a thread in here somewhere about how to modify the OFT log files (just change column names) so that they work with VirtualDyno.
flickr
Old 07-26-2014, 01:28 AM   #5
vynervt
Drives: GT-86
I try to use the VirtualDyno by I just cant get it right to show result.
Old 07-26-2014, 07:35 AM   #6
wparsons
wparsons's Avatar
^^ Have you followed the instructions in the thread on here about how to use OFT logs with it? It works for me every time.
flickr
GTech SS / RR Performance Data Accuracy TmP Engine, Exhaust, Transmission 4 05-29-2014 03:29 PM
FA20Club Dyno Day @ Phastek Performance (Houston, TX) PhastekSport Southwest 34 12-02-2013 08:39 PM
Infamous Performance is getting a Mustang Dyno whataboutbob Southern California 13 07-05-2013 08:49 PM
FR-S Dyno testing at DD Performance Research inc. 2ZZ comparison Boosted2.0 Engine, Exhaust, Transmission 120 04-07-2013 10:46 PM
Performance in Road racing and auto X. what not to do brzperformance.net Tracking / Autocross / HPDE / Drifting 27 09-20-2012 11:19 AM
