| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: 13 FRS
Self Service Car Wash?
I wanna go to a self service car wash.
What are the steps in washing? Anything I should bring? Anything I shouldn't do? thanks |
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
Shampoo, conditioner a loofah. Towel maybe to dry off. Some of that good axe paste to make your hair shiny
Drives: 2015 Series.Blue
Same as doing it at home, you just have access to heated and purified water (depends how good the place is) as well as high pressure (not that I use in on paint, but it helps to get wheel wells and undercarriage).
Drives: 2014 BRZ SWP LTD
DO NOT take your car to a self service wash... I can tell you that much.
Drives: 2014 Scion FRS
if your gonna have to take it there
follow these tips and tricks! [ame="https://www.youtube.com/watch?v=qQ32CqvgtMA"]How To: Coin Operated Car Wash Tips & Tricks - Chemical Guys BMW E39 530i - YouTube[/ame] |
| The Following User Says Thank You to WhiteFRS69 For This Useful Post: | skeet (07-21-2014) |
Cliuless
Drives: Whiteout Scion FRS 2014
Member of the year - 2016
Drives: Scion FRS
If you have to use a brush, then pass on it.
If it's a spray system that uses soap then water, should be fine. Do note that the soap may remove your wax if you have someone on the car, they tend to be a bit aggressive like dish soap. Some places have a blow dryer like contraption, if not then you'll have to bring towels. Microfiber towels, preferably drying ones. Edit: Using the brush for your wheels is fine. If you have a set of wheels that are too sensitive for a brush then why the hell did you buy them? Self service car washes are great for during the winter. Assuming they still work.
#10 |
I've always been told to avoid the recycled water. OP if you don't have access to a power washer, why not just use a waterless method at home? Look up optimum no rinse, or similar alternatives.
| The Following User Says Thank You to Turbo95eg6 For This Useful Post: | WhiteFRS69 (07-24-2014) |
#11 |
Drives: '13 10 Series FRS #1203
as stated DO NOT USE THE BRUSH
Use the sprayer, use the foam option on the sprayer if applicable then wash with your own buckets/mitt I only use self service during the winter, as I turn my outside lines off |
#12 |
Don't use their soap/sprayer. High pressure for water only if you can, but keep in mind it needs to be dried properly to avoid water spots.
#13 |
Drives: 2013 FR-S 10 Series #1186
Avoid wash bays with tons of shit and/or dirt caked on the floor. They're rarely sprayed down.
sent via mobile.
#14 |
| Can you recommend a hand wash car wash in Las Vegas | whaap | Southwest | 3 | 05-14-2013 06:55 PM |
| What to use to wash this car? | ntr0py | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 15 | 04-17-2013 10:36 PM |
| Car Wash | grgonium | CANADA | 14 | 01-14-2013 12:31 PM |
| Westchester, Queens, Bronx Self Service car wash? | #87 | NY / NJ / CT / PA | 7 | 11-05-2012 10:54 PM |
| How often do you wash your FR-S? | terrypm | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 50 | 07-14-2012 03:24 AM |
