Old 07-18-2014, 02:54 PM   #1
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
WORKS BP-1 Brake Package
We are pleased to announce our Stage 1 Brake Package for the FR-S and BRZ!
Often overlooked, brakes are one of the most critical elements of any high-performance machine. If you are building a car to go faster, then it makes sense for it to stop better as well. A good set of brakes will not only make your vehicle safer, it will also bring down lap times by allowing you to brake later into turns.
The WORKS Stage I Brake Package is designed for the entry-level enthusiast who mainly drives on the street, but may see some track or autocross action from time to time. This package combines our front and rear slotted rotors with the WORKS Blue brake pads to give you superb stopping ability on the street and the flexibility to use this setup on light track days. Our slotted rotors are designed to fit like OEM but boast superior construction for resistance to warping with directional vanes and machined slots to help dissipate heat and gases that build up under hard braking.
The WORKS Blue brake pads are a more aggressive street compound perfectly matched for these rotors. With a maximum operating temperature of 1050* F this compound has excellent grip at high temperatures, but unlike a pure racing compound the WORKS Blue pads come up to operating temperature quickly and are therefore safe for the street and more conducive to extend rotor life.
All of our brake packages also include the WORKS SS (Stainless Steel) Brake Lines for improved stopping performance and enhanced pedal feel along with 1.5L of Motul RBF 600 brake fluid.
The BP-1 Brake Package includes:
  • Set of WORKS SS Brake Lines (2 front, 2 rear)
  • Front WORKS Slotted Rotors (1 left, 1 right) Rear WORKS Slotted Rotors (1 left, 1 right)
  • Front WORKS Blue Brake Pads (4 pads)
  • Rear WORKS Blue Brake Pads (4 pads)
  • Motul RBF 600 Brake Fluid (3 500ml bottles)
Price: $829
Web-store link here: http://store.worksmotorsports.com/WO..._p/630.211.htm
WORKS is offline
Old 07-21-2014, 02:30 PM   #2
WORKS
WORKS's Avatar
A little more about what is included...
WORKS Stainless Steel brake lines are made in the USA and consist of the finest Teflon (PTFE) hose with stainless steel braiding which reinforces the assembly and our outer blue PVC sheath provides additional protection. Then zinc plated steel fittings are securely crimped to the ends of each line. DOT certified because safety in your braking system should not be compromised.
Over time and under continuous use, OEM rubber lines can swell and expand exposing the driver to brake fade. The rubber cover is also vulnerable to attacks from the ozone layer rubber which causes it to degrade and deteriorate.
Our performance lines increase safety and brake responsiveness due to no appreciable volumetric expansion in the brake lines.
They can also be purchased individually here: http://store.worksmotorsports.com/WO..._p/330.211.htm
WORKS is offline
Old 07-24-2014, 02:48 PM   #3
WORKS
WORKS's Avatar
Regarding our WORKS Blue brake pads,
WORKS has developed a brake pad specifically designed for someone who is going to primarily drive their car on the street but also wants to take it occasionally to the track.
With a maximum operating temperature of 950* F this compound will grip better under high temperatures, but unlike a pure racing compound the WORKS Blue pads come up to operating temperature quickly.
The WORKS Blue brake pads also work with a stock rotor setup unlike other more aggressive pads that will quickly eat up the OEM rotors.
In addition they will give you nearly silent operation when used in conjunction with the factory shims and installed properly.
If you are planning the occasional track day, or are a track novice and want a great setup for both the road and track, the WORKS Blue brake pads are for you.
Individual web-store listing here: http://store.worksmotorsports.com/WO...11_306.211.htm
WORKS is offline
Old 08-01-2014, 06:07 PM   #4
WORKS
WORKS's Avatar
WORKS Slotted Rotors - Front
WORKS Slotted Rotors are direct OEM replacements, provide better performance and less prone to warping because of their superior construction.
Each rotor is slotted to help prevent gasses from building up between the rotor and pad surfaces while the directional vanes offer improved cooling over the typical straight vane design.
WORKS Slotted Rotors - Rear
Individual listings below.
WORKS Slotted Rotors (Front): http://store.worksmotorsports.com/WO..._p/320.211.htm
WORKS Slotted Rotors (Rear): http://store.worksmotorsports.com/WO..._p/323.211.htm
WORKS is offline
Old 08-08-2014, 03:31 PM   #5
WORKS
WORKS's Avatar
Keep in mind, we are still offering a one-time 10% discount on any order of WORKS brand products!
Just enter ft86club in the coupon code box when you order!
WORKS is offline
Works Bell, Nardi, Personal, and Keys Package deals and Shift Knobs Evasive Motorsports Interior Parts (Incl. Lighting) 90 07-10-2017 05:47 PM
GTS Brake Package (Discs, Pads, Lines) DanVIIIVI Australia Classifieds 5 01-11-2014 03:32 AM
Which brake package is the better value vignesh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-20-2013 09:47 AM
WORKS Stage 1 Complete Brake Package Upgrade 86_ZN6 Brakes, Suspension, Chassis 1 05-28-2013 04:57 PM
