Old 07-16-2014, 12:40 AM   #1
86ING IT
Drives: 2013 scion frs
Running 3000k fog lights?
I installed aftermarket foglights and want to upgrade the halogens to 3000k HID foglights with a 55w ballast. Anyone running this? I've been reading up and got mix reviews on if I need a relay harness or not? Anyone running this setup without a relay harness and have any issues?
86ING IT is offline   Reply With Quote
Old 07-16-2014, 12:59 AM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I'm running hid in headlights and in fogs. All I needed was a switch for mine.
Chen is offline   Reply With Quote
Old 07-16-2014, 01:09 AM   #3
86ING IT
Sorry r u talking about the on and off switch designated for the foglights? I'm running HID on my headlights right now but with a relay harness.
Old 07-16-2014, 03:26 AM   #4
Chen
Regional Moderator
Chen's Avatar
Yeah the on off switch.
Old 07-16-2014, 03:33 AM   #5
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Using the relay harness as well. Was using HID's but I figure I'd clear up some clutter in my engine bay and just went with these:
http://www.ebay.com/itm/191236634492...84.m1497.l2649
Prefer them so much more over my HID's
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 07-16-2014, 10:26 AM   #6
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
^I second using the yellow halogens. I'm using the Hella Yellow H11s and they look great, they are cheap (you can get them at pepboys) and no ballasts to worry about.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 07-16-2014, 11:39 AM   #7
Diode Dynamics
Diode Dynamics's Avatar
I strongly recommend switching to a 35 watt kit, especially since you are using them in the fog lights.
55 watt kits generate considerably more heat than a 35 watt kit, and in a smaller fog light housing you are greatly increasing the chances of heat related damage.
Nick C.
John C.
Diode Dynamics
Old 07-16-2014, 12:34 PM   #8
86ING IT
Nick C.
Anyone here on the forum run into issues with running a 55w foglights ?
Old 07-16-2014, 12:41 PM   #9
86ING IT
Do u have 35w or 55w ballast on Your foglights?
Old 07-16-2014, 01:00 PM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Nick C.
I purchased your glass fog-light kit. Are 55 watt hella optilux yellow bulb halogens ok for use in these or are we just talking hids here?
http://www.ft86speedfactory.com/diod...ghts-1288.html
Old 07-16-2014, 02:15 PM   #11
Chen
Regional Moderator
Chen's Avatar
35 watt running 6k hids. It's bright as hell. I feel like I can drive without headlights sometimes.
Old 07-16-2014, 02:20 PM   #12
STS-V
I have 6k 55w HIDs and 3k 35w Fogs. Both are ran on relay harness, the fog ignition switch is triggered from the headlights.
STS-V is offline   Reply With Quote
Old 07-16-2014, 02:24 PM   #13
8R6
8R6's Avatar
Drives: FRS
55w hid's are pointless in foglights
8R6 is offline   Reply With Quote
Old 07-16-2014, 04:53 PM   #14
Diode Dynamics
Just talking about HIDs
Nick C.
John C.
Diode Dynamics
LED daytime running lights sav AFRICA 168 03-22-2016 04:26 AM
best LED daytime running lights trigger happy Cosmetic Modification (Interior/Exterior/Lighting) 8 11-15-2013 10:00 PM
OEM LED running lights 5spd Exterior Parts (Aero, Lighting, Etc.) 1 11-04-2013 08:21 PM
Led Daytime Running Lights to Fog Lights conversion? mfbmike Cosmetic Modification (Interior/Exterior/Lighting) 1 08-24-2013 07:47 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
