Old 07-14-2014, 12:37 PM   #1
jp_r6
E85 tune
Just a question, see all this about e85 tunes, my question why?
jp_r6 is offline   Reply With Quote
Old 07-14-2014, 12:44 PM   #2
raven1231
Power?
Old 07-14-2014, 12:53 PM   #3
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
So that we can keep demand up for corn consumption thus allowing our government to continue subsidies for farmers which in turn generate huge profits for large corporations that own that farmers.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-14-2014, 12:54 PM   #4
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
SEARCH!
E85 is 105 octane.
With NA its the differance between 160whp and over 200whp
With turbo on stock compression its the differance between 320whp and 600whp
The Following 3 Users Say Thank You to Reaper For This Useful Post:
DAEMANO (07-16-2014), raven1231 (07-15-2014), Sportsguy83 (07-14-2014)
Old 07-14-2014, 09:24 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
http://lmgtfy.com/?q=FRS+E85
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
continuecrushing (07-15-2014), Kronos (07-14-2014)
Old 07-15-2014, 05:19 PM   #6
Argento86
Drives: Argento
The power is so much more smooth and you feel the differences everywhere. I only have an air filter and the e85 tune and I could not ask for more of value than this upgrade. If you have an OFT already give it a try but be prepared to hate 91.
Argento86 is offline   Reply With Quote
Old 07-15-2014, 06:29 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I see all these dumb questions all over the forums, my question why?
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 07-16-2014, 09:02 AM   #8
jp_r6
Ok some answers, but I was wondering why you would go this route if the motor currently not like e10 even. Also what is the long term effects of running e85,
Old 07-16-2014, 09:18 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
All of your answers are a simple google search away.... seriously.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Reaper (07-16-2014)
Old 07-16-2014, 09:23 AM   #10
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
I agree, I have access to 93 and still hates it when I switch back from E85.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-16-2014, 09:28 AM   #11
steve99
The motor does not like low octane fuels , not all alcohol (ethanol) containing fuels are low octane.
It not the ethanol that the problem it the low octane petrol its mixed with
91 E10 is most likely 87 petrol with 10% ethanol to bring the octane rating to 91
Yes a lot of 91 octane fuels contain 10% ethanol but so do some 94 octane fuels.
Ethanol has a higher octane rating than most petrol around 105 (USA rating)
However ethanol has a lower energy content per volume than petrol, hence your fuel economy may be slightly worse on E10 fuels.
It also a very clean burning fuel
This car like most modern vehicles is compatible with E10 fuels (states so in manual) but for best results and performance you need to run 93 (USA rating) octane fuel or better, else the motor will knock resulting in the ECU pulling ignition timing and hence reducing power.
To run E85 fuels the ECU needs retuning to add significantly more fuel aprox 25-30 percent more to avoid the motor running lean, but due to the higher octane rating of ethanol you can also increase the ignition timing significantly resulting in approximately 20 wheel horsepower gain on a stock car, with significant increases in power and torque across the entire RPM band
Turbo or supercharged cars can extract significantly more gains from E85 as they can fully utilize the much higher octane rating and increase boost pressures as well as timing as well as the cooling effect of the extra fuel.
http://www.google.com.au/?gws_rd=ssl...3Aft86club.com
Old 07-16-2014, 11:53 AM   #12
Reaper
Reaper's Avatar
Drives: violent
pumpgas mixed with e10 does not contain additional lubricants to counter act the small amount of ethanol. E85 contains additional lubricants to account for the ethanol. E85 changes to somewhere around e70 in the winter to assist with cold starts.
Long term effects? More power, cleaner burning engine, no sludge buildup what so ever, lower emissions, less dependency on foreign oil, more frequent oil changes and possibly longer hp di fuel pump life.
sooo.....yeah start buying e85 now because the government subsidiary is about to run out and if the public doesn't catch on the price will go up and it will start to disappear.
The problem is with uneducated people saying something about how its acid and will cause your engine to corrode and every molecule in your body will explode at the speed of light if you use e85.
Old 07-16-2014, 12:02 PM   #13
Dipstik-sportech
Dipstik-sportech's Avatar
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Pistol (07-17-2014)
Old 07-16-2014, 12:05 PM   #14
steve99
Originally Posted by Dipstik-sportech View Post
That would be almost drinkable with a little orange juice
waste on us NA guys about E60 is all we need
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 02:49 PM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 09:53 AM
