Old 07-14-2014, 12:27 AM   #1
BadBRZ
Drives: Subaru
Turbo manifold runner size
What would you consider an ideal diameter size for the manifold runners?
BadBRZ is offline   Reply With Quote
Old 07-14-2014, 12:40 AM   #2
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
We use 1.25".
Jesse@JDLAutodesign is offline   Reply With Quote
Old 07-14-2014, 09:42 AM   #3
mrk1
Drives: Sterling BRZ Ltd
^^^ I'm assuming thats nominal size. In practice thats a pipe with the ID of 1.442" for anyone curious.
The 2 manifold I have build so far have have 1.5" tubing.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-14-2014, 10:25 AM   #4
BadBRZ
Drives: Subaru
I'd imagine you would want to reduce restriction without reducing velocity of the gasses or flow.
There has to be a formula to calculate ideal I.d. For a given length runner on our cars...
http://www.pipeflowcalculations.com/...w-in-pipes.php
This will be fun
Old 07-14-2014, 01:33 PM   #5
D K
Stig's dark passenger
Sub'd
D K is offline   Reply With Quote
Old 07-14-2014, 02:53 PM   #6
Jesse@JDLAutodesign
It's actually 1.35" with the thickness we use.
Old 07-14-2014, 09:49 PM   #7
ciro
Drives: Scion FR-S
The smaller the diameter the higher the flow but less volume. The trick is the balance between the two. You need to have a length in mind. So for example for a UEL header the shortest length should be the largest diameter and the longest length should be the narrowest by theory. In practical it is the average length that you should use to calculate the diameter to get a good overall idea of where to start. Lots of headers for turbos are generally more narrow then NA headers.
ciro is offline   Reply With Quote
Old 07-14-2014, 10:55 PM   #8
BadBRZ
Drives: Subaru
This is exactly what i'm referring to. The issue is which diameter will be ideal for spooling a specific turbo
Old 07-14-2014, 11:36 PM   #9
taylork057
Drives: 2013
depends on purpose... 1.5 is great for regular folk who wont tell the difference.
taylork057 is offline   Reply With Quote
Old 07-15-2014, 09:57 PM   #10
ciro
Drives: Scion FR-S
Its not about the turbo in any way other then the entrance surface area of the turbo. You need to calculate the length to the turbo.
Rough idea is that you match the header outlet surface area which in our case is circular so its easy to use that diameter. If you want to increase the velocity of your exhaust to potentially quicken your turbo spool speed without changing it you simply step the header down to a smaller diameter for a short distance before the turbo. This will however increase back pressure and you may not get the results you are looking for if you are not careful and go to small.
Cannot find the thread that someone tested a few headers on his WRX. He originally bought a 2 inch runner diameter header and hated the spool time. I think it was around 4500 rpm. He bought new a new header with a 1.36 inch diameter and his spool time was reduced by almost 2000 rpm.
What turbo are you considering?
Old 07-18-2014, 09:27 AM   #11
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
now i dont have numbers but...my fullblown base manifold with a gtx28 makes more torque substantially sooner than a few of my friends cars with similar kits and setups. It would be interesting to see the size compared to jdl, as a friend with their kit produced the closest results to mine vs some others. (albeit other factors nonwithstanding) I would ask lj what their size is, as it seems pretty ideal by comparision.
Just a start.
Old 01-25-2015, 06:24 AM   #12
Mike Brz
What size are the exhaust ports and what size is the stock runners?
Mike Brz is offline   Reply With Quote
Old 01-25-2015, 08:46 PM   #13
mrk1
ports are 1.5" not sure about stock runners
The Build Thread
FS: FA20club EL turbo manifold cb7tuner Engine, Exhaust, Bolt-Ons 1 07-08-2014 04:17 PM
Turbo Manifold Admired Forced Induction 1 08-26-2013 12:19 AM
Turbo manifold evanmd Forced Induction 20 07-31-2013 02:39 PM
Manifold nut size Bullnettles Engine, Exhaust, Transmission 5 06-11-2013 12:02 PM
WTB Turbo manifold evanmd Engine, Exhaust, Bolt-Ons 0 06-02-2013 07:02 PM
