Drive From Home
Drives: BRZ STI Performance
Air Spencer Vent Attaching Type *Solved*
If you are coming from an older car and already have an Air Spencer Giga Clip air freshener or two lying around, you probably have already noticed that there is no room to clip it onto the center vents.
![]() The solution is to get the newer Air Spencer Clipia which takes the same refills: ![]() The Clipia does not have an open/close vent like the Giga Clip, but the body itself is aluminum and being half the size it's much lighter. It comes in a twin pack (to take the two stick refills one on each). The only thing to note is that the Giga Clip does come with a more durable steel clip than cheap plastic clip on the Clipia, but the good news is that the clips are readily interchangeable. To change the refill it's much easier by just sliding the Clipia body off the steel clip, leaving the steel clip attached to the vent flap. http://www.airspencer.com/index.html Squash FTW! |
Drives: 2014 BRZ
Where can I get these online? Saw like 2 sites that sell them, but they look a little sketchy.
| DIY - Air Spencer | P@ul | DIY (Do-It-Yourself) Guides | 6 | 03-02-2014 02:04 PM |
| Spencer Strayer's Ultramarine FR-S | Spencer Strayer | Member's Car Journals | 33 | 04-09-2013 07:26 PM |
| GIGA AIR Spencer? | NemeGuero | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 12-13-2012 02:30 PM |
| error when attaching pdf to post | dude04 | Site Announcements / Questions / Issues | 0 | 05-21-2012 08:53 PM |
