Drives: 2014 Scion FR-S
need help, trunk problem!!!
Hey so I can't open my trunk with the FOB or the button in the car? The key and the emergency latch work fine... what should I be looking for? Fuse? Wiring?
Thanks for any help!
Thanks brother, worked!!!
Mumbler
Drives: Sensibly
http://www.ft86club.com/forums/showp...01&postcount=2
I'm sure we'll all hit this button at some point. It's good to know about it. |
#5 | |
Drives: Moped
yea I always have something in the trunk that slides and presses it...
someone should fab a little cover for it... |
Drives: 2013 Asphalt 6spd
#10 |
Drives: 2014 BRZ Limited
Can you not just jump the connection with a paper clip to close the circuit and wrap a slice of electrical tape around it? (This is how Jeep guys fix the door control lockout button when it fails.)
#11 |
#12 | |
I think most of the sensor inputs are normally closed on this car, and the buttons open them. I unplugged my drivers seat belt sensor planning to jump it so it wouldn't ding at me every time I start the car (to let the idle settle) before I fasten my seat belt, and just by unplugging it, it thinks the seat belt is always fastened. Got the same thing on the trunk switch, unplugged it, and it thought it was always pushed, and the same thing on my door switch, unhooked it to cancel the window indexing, and now it thinks the door is always closed, instead of always open. but back on topic, a small piece of sheet metal, or even cardboard folded into a shallow open top box should slide over the button and fit flush with the panel to keep the button from being pressed by accident.. I've had it happen a few times to me too. |
#13 | |
#14 |
Drives: BRZ Sport-tech
It's probably a momentary switch with a code stored in the security module?
| Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 03:27 PM |
| WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk | R0ME0 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 01-07-2014 09:36 PM |
| Zeta & Carsmo Armrest, Weathertech front and trunk mats, OEM scion trunk carpet | HighbreadEH3 | Interior Parts (Incl. Lighting) | 16 | 07-29-2013 10:42 AM |
| Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) | Iamthebatman | Exterior Parts (Aero, Lighting, Etc.) | 2 | 07-18-2013 02:12 PM |
| WTT Raven FRS wingless trunk for your Black BRZ limited spoiler trunk | Tylub | Exterior Parts (Aero, Lighting, Etc.) | 0 | 05-12-2013 08:21 PM |
