Old 07-11-2014, 03:07 PM   #1
ThatManAnt
Drives: Whiteout FR-S 6spd
Just Ordered some ST coilovers
I've looked at installations on these on the forum and other coilovers. Just making sure im not gonna need a spring compressor for this car? Didn't on my TC. But no ones said anything about it so i'm guessing its not needed? thanks.
ThatManAnt is offline   Reply With Quote
Old 07-11-2014, 04:02 PM   #2
jonzhuxD
Drives: Ultramarine FR-S
Nope, take out the factory coilover and install the ST in it's place
jonzhuxD is offline   Reply With Quote
Old 07-12-2014, 12:46 AM   #3
daibunjau
Drives: 2013 Scion FRS
Pretty sure you need a spring compressor to swap over the OEM top hats
daibunjau is offline   Reply With Quote
Old 07-12-2014, 03:09 AM   #4
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
loosen the stock suspension before raising the car, and then hand tighten everything and use the cars weight to compress the springs. It's not the best method but it works, I did it. Make sure you get the rear strut rod tight enough or you'll have a horrible metal on metal noise.
Thunderleg is offline   Reply With Quote
Old 07-12-2014, 03:48 AM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Check the diy section for the easier spring stru install to describe the way mentioned above. I have used it on multiple twins with good results.
Old 07-12-2014, 04:09 AM   #6
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
no need spring compressor for stock struts.. you wont lose a limb..
if you have previously lower springs installed, try to lose top nut the spring will release
load = spring stiffness x distance
decrease the distance = lower the load
hanabie is offline   Reply With Quote
Old 07-12-2014, 08:28 AM   #7
FR-S Matt
You really should use a spring compressor. After doing two coilover installs, it's not very safe to just loosen the top on the stock struts. It will shoot off and with a lot of force. Coilovers you don't have to worry about that if you're swapping top hats that way. Definitely rent some from auto zone or buy a set. Not worth risking a trip to the ER.
Old 07-12-2014, 09:53 AM   #8
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I've done two spring installs on this platform. You don't need compressors. If you loosen the top hats before you raise the car, all compression (barely any) is dissipated.
Old 07-12-2014, 10:05 AM   #9
hanabie
hanabie's Avatar
Op.. if u really worry about it, autozone gives free rental for spring comp I believe. But I did two times springs install. I had zero issues without top nut shooting up like bullet.
Old 07-12-2014, 11:48 AM   #10
FR-S Matt
My top hats shot off even a bit while compressed, but hardly any. There's a reason why there's a huge warning in the DIY section about placing it against something hard if you're not going to compress the spring.
Old 07-12-2014, 11:54 AM   #11
boredom.is.me
Custom User Title
If you COMPLETELY loosen the top hat from the strut while the car is on the ground, the factory coil over disassembles itself. If you remove the still assembled coilover, then of course you will have a little pressure. But even that isn't much. I've done it both ways.
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
Pre-Ordered JR SC? ramiram1984 Forced Induction 4 10-28-2013 03:43 PM
Those of you that ordered your FR-S Synack Scion FR-S / Toyota 86 GT86 General Forum 55 07-20-2012 08:15 PM
FR-S pre-ordered ! but ... QC-FRS CANADA 11 04-20-2012 01:53 PM
Just Ordered the FR-S SunnyD Scion FR-S / Toyota 86 GT86 General Forum 81 03-03-2012 12:16 AM
